Question about HTC Touch P3450 Smartphone
HTC ELF100 I bought this phone second-hand and don't have the CD rom that would've came with it to install the software to connect it to my computer. Is there anywhere I can download the software for free?
Yes i can help you for that i have the cd rom ok. my email is arthuribekwe@yahoo.co.uk
Posted on Sep 29, 2008
I have a razor motorola A41x/V32x from metro my screen is broken I have pictures that I've been trying to get for the past 3years. Everytime I connect it to the computer it ask me for the cd-rom but I...
you need to install the software that is required for the computer to recognize the phone is connected and access it memory, I have this phone and I do have the software, got it on ebay.
Feb 06, 2012 | Computers & Internet
I purchased some software to monitor calls on my daughters cellphone. the software was sent to me and i need to save it to my computer and then download it to my HTC thunderbolt phone. how do i do this?
The software installation file you have purchased is in "APK" format which is what Android will recognize as an application installer.
To install applications outside of the Market you must select/check "Unknown sources" which is located under "Applications" which is located under "Settings."
1. Connect the HTC Evo to your computer via it's USB cable.
2. Select mode of connection as "Disk Drive" (a menu with these options will pop up after connecting through USB).
After that is done, your computer will now recognize your HTC Evo as a Disk Drive.
3. Go to the location of the file you've download and want to transfer to you daughter's Evo- Select it, hold down "Ctrl" key while pressing the letter "c" (to copy the file).
4. Go to the location of the HTC Evo now known to your computer as a "Disk Drive" then hold down "Ctrl" key while pressing the letter "v" (to paste what you've copied).
Now that the file is on your daughter's Evo you simply need to:
1. Change the Evo's mode of connection from "Disk Drive" to "Charge Only" or just disconnect the USB cable.
2. Browse to the phone's app directory to start a file manager application (download one from the Market if you don't already have one- I recommend "ASTRO File Manager").
3. Navigate (using the file manager) to the file you've transferred to the phone and just launch it. The next prompt will ask if you want to install the application- select "Install."
Done.
Aug 13, 2011 | HTC EVO 4G Smartphone
Unloc my HTC Elf100
you can Unlock your HTC Elf100 with imei unlock code. it is very simple and eaisiat way to unlock your HTC Elf100 . get your HTC Elf100 Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Jul 05, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
I can't turn on bluetooth for htc hd2. it said" Error in loading the Bluetooth stack (oxi)
Hello Tuy,
It seems that you have to update the software of HTC HD2 Smartphone. HTC provides Rom Upgrade in which it completely replaces the built - in software in the phone. Rom upgrade in the HTC HD2 Smartphone extends its features, imroves its performance which makes it easy to use.
Download the Rom Upgrade from the link provided below :
http://www.htc.com/www/SupportDownload.aspx?p_id=297&cat=2&dl_id=856
Rom upgradation completely erase the personal data and the customized settingsor any installed programs in the
HTC HD2 Smartphone. Before Rom upgradation pleas backup all your data.
Please visit the below links to backup your data before upgradation :
http://www.htc.com/www/howto.aspx?p_id=297&id=191
http://www.htc.com/www/howto.aspx?p_id=297&id=187
During ROM upgrade, make sure that your phone battery is at least 50% charged. Automatic standby and hibernation are disabled in computer, and close all running programs. Do not disconnect your
HTC HD2 Smartphone from your computer while the phone software is being updated. If you disconnect the HTC HD2 Smartphonee during the software update, it may become unusable.
Jun 05, 2011 | HTC HD2 Smartphone
Re: Samsung CD-Rom SC-148C in Dell Dimension 2350 Cannot eject/open tray to CD-Rom - I have tried ejecting tray while re-booting from setup to see if its a software problem of some kind. I've...
  1. Turn off the power to the computer.
  2. Insert a steel rod (about 1.3 mm in diameter) into the emergency eject hole and push hard. (A stiff paper clip may be used).
  3. The disc tray is ejected a short distance. Pull it all the way open by hand. roadfox_2.jpg
Jun 01, 2011 | Samsung SC-148 CD-ROM Drive
I bought an HTC S710 without an installation CD. What do I do?
Hema.
I lost my HTC S710 installation CD i am unable to connect to my pc. pls help me.. where can i down load software.
plsss..
Feb 07, 2009 | HTC S710 Smartphone
I want to be able to transfer photo's from my phone to the computer but i have lost the software disc. Is ther any way a new one could be snt out. I havr the HTC touch dual.
I bought the HTC P3450 ( ELF) second hand and didn't have the software CD. I downloaded a copy of ActiveSync version 4.5 from Microsoft.
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync45.mspx
I was then able to access my phone using ActiveSync (by connecting via the USB cable) and use the Explore option and copy any photos to my computer by simply 'dragging and dropping them to my desktop.
Hope this helps ! I am a newbie to all this and this worked for me :)
Oct 11, 2008 | HTC Touch P3450 Smartphone
Touch software CD rom start up disk
hi
i'll try to see if i can copy the cd rom for you and if i did i'll post it for you ok.
Sep 29, 2008 | HTC Touch P3450 Smartphone
Htc_s710 support cd/software
in which area do you live, i have the CD that came with my HTC 710 regards
peter
Jun 11, 2008 | HTC S710 Smartphone
HTC Touch P3450 Smartphone Logo
188 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
