Question about Sport & Outdoor - Others
Bicycle handlebars move seperatly from the wheel
When i try to ride my bike the handlebars move independently of the front wheel i have tried to tighten everything but i dont know if there is something i am not doing which i should be
    Novelist:
  • 137 Answers
My guess is that you are using an older, "quill" stem, which is both the STEM (the extension that the handle bars attach to) and the friction bolt that tightens the stem into the STEERING TUBE
Anyway, what I think has happened is that the quill is either not tightened or (because you said you tightened everything) the angled nut at the end of the quill isn't aligned properly and is tightening.
HERE is a great diagram of the quill stem. What I think you'll need to do is:
1 ) IF you have already tightened the bolt at the top of the stem (usually under a little plastic cap, like the one at the top left of the stem in the diagram). Then Untighten it and if you can pull it out make sure that the angled nut (shown at the bottom) is resting properly against the angled shaft of the quill (the vertical part of the stem). As you can see these will spread apart as you tighten the bolt, making them wider and holding them in the steering tube. The idea is to realign the angled nut so it can properly contact the shaft and spread.
2) if you haven't tightened this bolt (maybe because it's hidden), try tightening it a small amount and see if that changes anything.
__________________________
This was all written assuming your bike is not using the newer "threadless" setup, which would probably have been fixed if you tightened down the stem (PICTURE OF THREADLESS STEM)
Posted on Oct 09, 2008
  • 181 Answers
Most older bicycles have a bolt running straight through the handlebars.in the middle of the handlebars is there a allen key head or a single 10 mm nut head, depending on the bicycle you have. some have four screws holding a bracket on ,theses have notches to stop the bars from going up and down. look under the plate to see if there is any way of tightening the bars up. hope this helps
Posted on May 12, 2009
What is the shape of the handle bars on the Schwinn High Timber Girl's bike?
These are certainly not racing style bars; but the modern, hybrid riser handlebar.
They will not sweep back toward the rider as much as a beach cruiser handlebar; but could be adjusted rearward to come closer to the rider. They definitely allow for a more upright riding position than many other handlebars though.10_19_2012_7_26_19_pm.jpg
Oct 19, 2012 | Schwinn High Timber Girls' Mountain Bike...
Tip
Bike sizing tip
Your bike must fit properly to be safe and comfortable. In the case of road bikes, most people will agree that you should be able to stand over the middle of the toptube on a man's style frame, with your feet about twelve inches apart, and be able to lift the front wheel one or two inches. For bikes that will be used for off-road riding, you should be able to lift the front wheel 4 or 5 inches. The reasoning is not that you may hurt yourself by hitting the toptube in an accident, but that while you are trying to prevent an accident, you may have to put a foot down here and there. You should not have to be concerned about hitting the toptube, so you can focus on the problem at hand. Getting a bike that's too small means the handlebar may be too low relative to the seat for good comfort and control.
on Dec 21, 2010 | Cycling
How do I raise the handle bars on a Diamondback Sorrento? Purchased new in June. 16" frame, 26" wheels.
Web search teh question "How do I raise the handlebars".
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Aug 07, 2011 | Diamondback Cycling
I want to move the handbars up, but I can't figure it out.
http://www.sheldonbrown.com/handsup.html
Jul 09, 2011 | Diamondback Sorrento 26" Mountain Bike
How do i raise the handlebar on a 1999 MGX bicycle?
You can only raise a quill stem os far safely. Loosen the vertical center bolt that's in line with the steerer tube a few turns and then tap down on it with a block of wood or rubber mallet to unseat it. The stem should be loose enough to turn independently of the front wheel. You can also raise it somewhat, but look carefully for the "maximum height" or equivalent markings etched into the stem body. Don't expose any more stem than up to that line. Line up your handlebars with the front wheel and securely tighten that bolt. It should be tight enough to vigorously resist independent rotation when you hold the front wheel bewteen your knees and attempt to turn the handlebars.
If it's a new-style threadless type stem, the maximum height was determined when they assembled the bike because they had to cut the steerer tube to be below the top edge of the stem. Go to a Bike Shop and have them replace the stem with one that has a higher rise or shorter reach.
Aug 22, 2010 | Mongoose MGX Maxim Dual Suspension...
I just purchased The Cruiser 24 classis Huffy bike and can not find how to raise the handel bars. Is there a way to raise them up higher?
The center bolt on the stem tightens an expander wedge down inside the steerer tube. Loosen it a few turns, tap down on it to dislodge the wedge and the whole assembly should rotate independently of the wheen and you should be able to move it vertically.
The stem can only be safely raised so far. There will be a 'minimum insertion ' mark etched on it. Don't go any higher than that or you may die when the stem suddenly pops off the bike while you're riding it.
Get it to the height you want, align the handlebars square with the front wheel and tighten the bolt. While holding the front wheel between your knees, try to rotate the handlebars to make sure they're locked to the steerer tube.
If you need more height the stem would have to be replaced with one having a higher rise, shorter reach or some combination. A bike shop will have what you need.
Aug 08, 2010 | Cycling
Son's can pedal 12" bike
Yes, something isn't turning freely. It's either the front wheel, the back wheel, or the pedals and chain. Lift the bike off the ground and turn the front wheel by hand. If it doesn't turn very freely, it could be the hand-brake is dragging or the hub bearing is too tight. Try the back wheel in both directions. It should move freely in the forward direction. When rolling it backwards it is normal for the pedals to move too if this bike has a coaster brake (that is the kind of brake that is applied by pushing the pedals backwards.) It the back wheel moves forward freely, but backwards is a problem, then try the pedals by hand with the rear wheel off the ground. If this doesn't turn freely, the pedal crank bearing (a.k.a. bottom bracket) is too tight. Once you have identified the problem take it back to where you got it. It should be easy to fix, or they should replace it.
Jul 28, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
I fell on my bike and the handlebars and stuck to the right side.
Depending on the bike, you will most likely have a nut at the top of handlebar stem or two socket screws at the side of the stem that grip the front fork. In either case you need to loosen them slightly, reposition the handle bars and then tighten up. Quite often however if you stand in front of the bike with your legs on either side of the front wheel and turn the handle bars their is enough slip to move them back. Be carefull you dont strain anything if you dont back the threads off.
Sep 03, 2009 | Cycling
Raising the handlebar how do you do it?
PUT THE FRONT WHEEL BETWEEN YOUR KNEES AND TWIST HANDLE BARS FROM SIDE TO SIDE THEN SIDE TO SIDE AND UP AT SAME TIME THIS PART OF THE BIKE CAN BECOME RUSTED AND STICKY INSIDE TRY SOME WD40 OR ANY SORT OF OIL TO TRY AND GET IT MOVING AND BE SURE TO RE TIGHTEN NUT BEFORE USE HOPE THIS IS HELPFUL GLENN......
Nov 14, 2008 | Huffy 26in Mens Sante Fe Cruiser Bike -...
Sport & Outdoor - Others Logo
658 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
