Question about Garmin Nuvi 760 Handheld GPS Receiver
Touch screen cracked - can it be repaired and how much will it cost?
  • Casino Dagin
    Casino Dagin Jan 06, 2009
    LCD Monitor Touch Screen Crack. How do I solve this problems?
  • Anonymous May 16, 2009
    broken screen nuvi 760, can this be repaired
  • 3 Answers
Okay, first post was just a test to see if I could post before typing all this out.
This is for a Garmin Nuvi 760
First, you can find a new touch screen on E-bay for about 10 dollars. The LCD+touch screens are about 60. If you just cracked the screen but the display looks fine, you can just replace the touch screen.
Now, for do-it-yourselfers. To open the back of the case, there are 2 small torx (star) screws on the back to remove. If you don't have a torx driver, sometimes just the right size eye-glass screwdriver can fit but be careful not to strip the heads. Once those are out, you need to seperate the back casing from the front. I used an old credit card to pry gently with all the way around until it pops off. Don't force it, just be patient, it will come off.
Next, I recommend unplugging the speaker and battery so you can put the back aside for more room. There are 4 more phillips screws on all 4 corners of the circuit board. Take those out and the board comes out relatively easy. Don't force it. Once it is loose, there isn't much room to play with because of the ribbon cables. The large one is the LCD, the 4 pronged one is the touch-screen. There is a lever that lifts up and secures them in place. I got away with leaving them connected, but they are fragile and easy to tear. Next is separating the silver plastic part of the case from the black front that goes around the screen. I pried a bit with an eye-glass screwdriver around the area where the earphone jack and memory card go in. Again, using a credit card to pry all the way around is best that it won't leave scratches. Don't force it, just be patient.
Once you have that off, remove the screen from the case. I did it by pushing with light-moderate pressure all around the edges massaging it out. The touch screen and LCD have a rubber/leathery thin tape going around the perimeter. On the front, I got under it with an eye-glass flat head screw driver and slowly worked it around until it was free, being careful not to tear it. On the back, I used a razor-blade to un-stick it from the LCD, but be very careful not to damage the LCD screen if it's still working. The goal is to get this off in one piece. Once you have that off, there is the LCD and touch screen with double-back sticky black tape holding them together around the edges. I used a razor-blade. VERY CAREFULLLY separating them. Once that was done, I carefully scraped the remainder of the tape off the LCD which was un-reusable. I didn't know what to use for putting the new screen on since I didn't have that special type of tape, so after raiding my tools, I found some rolled butyl rubber for installing windshields. I cut small pieces of this off and put them around the perimeter of the new touch-screen (VERY THIN) in the same place the old one was, as if I was installing a real windshield. This took much patience, but in the end it worked great. Before putting the new touch-screen on the LCD, I blew it off with some compressed air, being careful to never leave a fingerprint on it while working on it. After putting it on, I pressed softly but steadily to get the rubber to even out so there wasn't any high points. Then, I replaced the same sticky tape that went around the perimeter of the 2 screens the way it was. It wasn't as sticky, but I made sure it was in place and it kept there by the pressure on the sides of the screen casing. Make sure you get it on right, because I think it's there as a shock-absorber so that the screen doesn't break as easily if dropped or jarred. I plugged back in the LCD screen into it's corresponding place on the circuit board and closed the tiny lever that secures it in place. Then comes putting everything back the way it was in reverse order. Be careful and go slowly, I ended up accidently pulling the ribbon cable out for the LCD and Touch screen and had to go back and reconnect them. This is a good time to attach the battery and turn the GPS on to see if you have all your connections made securely before everything is fully together. Put everything back together in reverse order, remember, if you have to force it, then don't. Don't forget to hook the speaker back up.
When it's all back together, if the new touch-screen doesn't tap where you tap it, you can calibrate it. This can be done by turning the unit off, then turning it on, then IMMEDIATELY switch it to the right(lock) position before it boots up and hold your thumb on the screen for about 30 seconds. There will be a callibration routine that will tell you to push dots on certain parts of the screen. If you do this with a stylus, it will probably be more accurate.
Now hopefully, you will be more careful and not drop your nuvi again. I hope this helps.
Posted on Sep 05, 2009
Unlock cracked screen nextbook 8
On some touch screen device, the tough part of the screen won't work when it has a crack. So it ill be difficult to unlock the screen as long as it has a crack. Ask yourself if it is worth repairing the screen, when you know what a repair shop asks for the repair and what a new device costs.
Success
Apr 25, 2015 | Nextbook Premium 8 Se Android
My 9" tablet's screen has broken where can i repair it. Am in Springs Ekurhuleni South Africa. My name is Pumeza. my email is pumeza.matiyela@implats.co.za
It's at all not worth repairing this old device. the screen can cost more than half the cost of a new tablet, unless the crack is only on the touch panel which is the clear glass mounted directly above the screen. In most tablets, both must be replaced because dismantling the screen or touch panel will usually damage the other. Better to buy a new tablet.
Feb 20, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
How to get rid of the crack on my ipod?
Phone repair shops can replace the screen. But it will cost. Knowing Apple is lowering the price for the new iPod Touch, I think you should try to fine out what a repair will cost and then decide to a repair or buy a new one.
You also could visit ifixit.com, because they show how to repair yourself. They also know what a new screen will cost and sell tools and spare parts if you need so.
Jul 12, 2014 | Apple iPod touch
FIX BROKEN SCREEN
It would cost more money to replace the touch screen than to just buy a new tablet pc. It cannot be repaired without putting in a brand new touch screen.
May 29, 2014 | ZEEPAD 7.0 Capacitive Touch Screen 512M/4G...
Screen of my samsung monte GT-S5620 is cracked in an accident. The display as well as the touch is fine. Just the glass is cracked. What to do with this problem as? how much it will cost? thank...
IM afraid you'll need to replace that screen. The sooner the better. The cost depends on your manufacturuer. If its only the front screen, it should be lkay, but considering is a resistive touch based interface, it might cost a significant amount.
Take it to a repair center.
Cheers
Mar 22, 2011 | Samsung S5620 Cell Phone
Viking designer 1 screen crack can't use touch screen sensor not working due to crack. can it be repair and how much would it cause me.
The touch screen can be replaced. The part is a little under $200 and the labor cost will vary with the repair facility that you use.
See an authorized dealer.
Jan 07, 2010 | Husqvarna Designer I
My ipod touch is cracked!!
it cost $30 because it is Arsenic free Glass
Jul 10, 2009 | Apple iPod touch
Cracked ipod touch screen
£53 from these guys www.ukipodrepairs.co.uk
Aug 21, 2008 | Apple iPod touch
Broken Elo Monitor Screen
Touch screens are even more expensive that straight LCD panels. This repair may cost more than the original monitor. Why do you need another panel? Is the panel cracked or is the touch screen portion not working correctly?
Dan
Mar 28, 2008 | Computers & Internet
Garmin Nuvi 760 Handheld GPS Receiver Logo
353 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
