Question about Panasonic DMR-E85H DVD Recorder
HD signals starting Feb 2009
Is there a HD tuner available for retrofit into the above unit?
  • choral Nov 02, 2008
    I have the same problem and do not have cable or satellite. With the IR Blaster for this unit work with any converter boxes?
  • janb7 Feb 03, 2009
    I have the same problem and wonder if the only solution is to buy a new DVR to get full functionality. I suppose Panasonic would not want to provide a retrofit because then they make less profit, unless, of course, the cost of the retrofit is sufficient to compete with the profit they make on a new DVR. But on the Panasonic website, the analog tuner is listed at only about $85 as a replacement part, so I don't see how they could justify a 100% or mark up for a digital tuner. I don't even know if a digital tuner could interface to the other components, not being a video engineer.
Well if you are on cable or satellite dish it won't be a problem....but if you use an analog antenna - you have no recourse.
Posted on Oct 03, 2008
Idk if my tv is digtal ready it says its hd
The TV will provide an HD picture with a set top box connected to the HD input (AV4 or AV5). It does not have a digital tuner (only a NTSC analog tuner).
The manual is available here: . See appendix B on page 58 for the specifications.
I hope this helps.
Apr 19, 2011 | Philips 51PW9303 51" Rear Projection...
How do I change my pro-730 HD to a digital signal?
You need a set-top box with a digital tuner. (For HD, you will need an HD digital source if you have cable or satellite. For OTA, you need one of those HD tuners; the digital-to-analog converters available with the government coupon last year were SD units.) You may be able to use a computer with a USB or PCI card tuner. However, you may be limited to the VGA input on the TV unless you use a converter or have a video card that can output in a TV format. (I can't find the specs for the DVI on the TV to tell if it is compatible with the RGB of the default computer signal.)
If you are getting an OTA signal, you will need an appropriate antenna pointed at the transmitter. Use or to find out the direction of the stations you should be able to receive. antennaweb is very conservative in the list it provides even though it assumes an outdoor antenna. tvfool gives more information on the antenna for each station in your area. Note: tall trees and buildings can block the signal even if you should get a signal. Digital signals are either enough for the tuner to read or no signal. An amplifier may be needed if you share your signal between several devices.
I hope this helps.
Dec 02, 2010 | Televison & Video
Can the tuner be upgraded to get digital signals?
There is no way to directly change the internal tuner to receive digital/HD signals. I would simply purchase an external tuner unit, but be sure to get one that has at least component signal outputs and is HD. You want to be able view HD & not just digital. One of the small tuner boxes would get digital, but not HD. I personally have a Digital Stream tuner with a set I own and have been very pleased with it. The tuner has many extra features and also has an NTSC output I use for recording with a regular vcr. Shop for an HD tuner unit. You will be impressed by the kind of performance you will get from this set.
Nov 09, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
US Govt Digital Conversion
You will need to hook up a digital TV tuner to the device.
Goto to request coupons for new tuners if you live in the US.
Nov 10, 2008 | Casio TV-880 2.3 in. Handheld Television
Feb 2009
hi there
wouldn't a set top box work attatched to the unit, the spec says it will ?
Oct 14, 2008 | LG Electronics LRM-519 Digital Media...
I'm trying to get the best picture for my 50'plasma tv. the picture is nothing like the one on display, and i've bought all the required gear
If you are using anything other than the HDMI input with HD programming the picture is going to look blotchy, when you see the tv on display, they are always playing a dvd disc and never have it on cable or satellite channels, this is because since the dvd is a digital format and looks very clean, by using the non-HD connections and since your tv has a digital tuner (mandated by the government) the tuner picks up interference from cell phones, WI-FI and police bands along with the cable signal and gets processed on the tuner, when everything goes to digital in Feb 2009 that will clearup considerably, but as for your question HDMI is the optimal connection to use
Aug 19, 2008 | LG Televison & Video
No, unless you are receiving over cable or satellite. You will need a DTV converter box if you are using an antenna to receive Over The Air television signals. The Proscan has an analog only tuner, so the ATSC (digital) signals will not be visible.
Jul 20, 2008 | Proscan PS27123 TV
Does my plasma need set top box
The changeover slated for Feb 2009 only effects those people that receive TV signals from antennas. If you currently use cable or satelite, you do not requrie a set top box. Your particular model has an HD tuner so you would be fine in both cases.
May 06, 2008 | Televison & Video
Adding HD to projection 43" TV
You will need to connect an ATSC tuner box to your TV. You can find a lot more information about the switch (and even some government coupons for the boxes!!) here:
Feb 17, 2008 | Televison & Video
acording to spec sheet this unit is not equip with a digital tuner you will need a converter box before feb 9 2009
Jan 16, 2008 | Televison & Video
Panasonic DMR-E85H DVD Recorder Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
