Question about Memorex Car Audio & Video
Tv won't turn on but vcr will
Memorex travelview 43055
I am wondering how to record a tv show on a blank VCR tape. The VCR I have is a Memorex MVR2031 VHS VCR. Can you help with step by step directions?
Cable from Programming source to TV. Tv OUTPUT cables to VCR INPUT. You will need to check the VCR Manual if you still have it. retrevo.com doesn't have your model listed since it's classified as obsolete, even though many people still have VCR only units.
You have to set your recording channels on the TV to match the switches on the VCR. May have to do it by menus, remotes or both and or just switches on the back of your units.
Here are some basic how-tos:
http://www.ehow.com/how_5024699_setup-cable-tv-vcr.html
http://www.ehow.com/how_5126493_record-tv-shows-vcr.html
http://www.mvrhs.org/library/How_to/TV/VCR_Recording.html
http://www.ehow.com/how_6849_hook-vcr.html
Setup varies based on source of programming (ie satellite, cable, etc) Good luck. Hope this has helped.
Mar 09, 2011 | Memorex MVR2031 VHS VCR
What are the tv codes for this tv?
Hello
Three digit universal remote code for Memorex are:-
002 115 206 502 506 601 701 706 000/ 001/ 004/ 009/ 046/ 049/ 051/ 135
Four digit universal remote code for Memorex are:-
0004 0009 0049 0051 0135 0031 0000 0268 0310 0001
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON the Tv each time with its front panel power ON/OFF switch, before trying an other code.
OK.
Jan 02, 2011 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Vcr
do you have a cable box/satelite/directtv? yes..okay box out to vcr in....vcr out to tv...(vcr must be set to ch 3 at all time)....no box at all, antenna should be connected to vcr/tv
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
Need Universal Remote Code for Memorex tv/dvd/vcr
I work for Memorex tech support. Our number is 800-919-3647.
Unfortunately, Memorex TVs and DVD players can not be controlled by universal or cable remotes. If you need a replacement remote, please call Memorex's parts distributor, Fox International at 800-321-6993 to make the purchase. If they no longer have stock, try www.remotes.com.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jun 25, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Problem with old TV
The channel is almost always 3 or 4. Be sure you have the VCR connections correct. Just hook up the TV and VCR alone to start with and try both the VCR and DVD. Also the output of the VCR should show a blue screen.
Dec 17, 2008 | Memorex MT1194 19" TV
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
Close caption
Should be under the menu/setup button on remote under close caption.
Oct 22, 2007 | Memorex MVT2135 13 in. TV/VCR Combo
Memorex mvt 2135b
Either a clock battery on the board (soldered in) or jumper inside. There was a remote code for hard reset, but I cannot find it. See if the website has support and email them for the code.
Apr 08, 2007 | Memorex MVT2135 13 in. TV/VCR Combo
Car Audio & Video Logo
20 people viewed this question
Top Memorex Car Audio & Video Experts
xxxxxx xxx
Are you a Memorex Car Audio and Video Expert? Answer questions, earn points and help others
