Question about HP Hewlett Packard 6910p 2.2GHz Intel Core 2 DUO T7500 2GB 160GB DVD+/-RW DL 14.1" WXGA WLAN BT Windows Xp Pro KR923... PC Notebook
Boot issue while booting it says " windows cannot b repaired"
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Please detail exact situation when this occurs. For example, turn on machine, get screen x, y, z, then... Also, have you checked to make sure that you don't have a CD (especially a Windows CD) in the drive? It almost sounds like the system believes that you want to repair Windows for some reason...
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 27, 2008
After pressing the reset button for several times, still my laptop Will not boot .all I see loading OS image
If you're having boot problems on your Windows PC, it's often helpful to repair the MBR (Master Boot Record) to restore the Windows 7 boot loader-and you can do it easily from the Windows installation disc. How to Manually Repair Windows 7 Boot Loader Problems
Resetting Windows 7 Password No need for Windows Installation CD or...
Oct 21, 2015 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Boot manager is missing HP pavilion dv6 notebook windows 7
This sounds like a common issue. The boot manager file "NTLDR" Can become corrupt or go missing due to a few situations.
1) Shut down improperly
2) Virus
3) Bad hard disk
4) Windows being windows.
Too fix this simply use a windows 7 cd and boot from it.
Choose the Repair option and let it do its thing. If i recall there's also a repair startup option you can use aswell.
Windows repair usually fixes the problem but if that doesnt work you can also put the hard disk into another computer and copy over replacement boot loader files.
  • ntldr, the main boot loader itself
  • NTDETECT.COM, required for booting an NT-based OS, detects basic hardware information needed for successful boot
    Try that. The windows repair usually works but if you have to use the alternative and it doesnt work it could be your MBR. Windows repair also fixes this but theres an old command you can run from the dos shell of the cdrom "mbrfix or fixmbr" That will take care of it.
    Good Luck :)
    Jun 08, 2014 | HP Pavilion dv9000z Notebook
    My acer aspire 5515 laptop system error window show when I try to boot. Hiw do I fix it?
    so what i guess its giving mbr not found and its not booting , the solution is you need to have the windows operating system disk and then when your acer laptop starts to boot click on f8 then click on repair windows then after that you will see 3 option click on the third it will say repair cmd then type as what is given below
    Click on the "Repair Your Computer" option to gain access to the System Recovery window. Now choose "Command Prompt" to run the Bootsect.exe utility. Bootsect is located inside the boot folder so change your directory to boot. Now run "bootsect /nt60 C:\" (without quotes) if you had Windows 7 initially installed in the C partition. Alternatively, you can run "bootsect /nt60 SYS" or "bootsect /nt60 ALL" (without quotes) to repair the system partition or all partitions. Eject the DVD and restart your computer. Your computer should now boot Windows 7 again.
    Read more: How to Repair the MBR on Windows 7 ' eHow.com http://www.ehow.com/how_4836283_repair-mbr-windows.html#ixzz2CY96TyX0
    Nov 18, 2012 | Acer Computers & Internet
    Bootmanager missing
    The latest versions of Windows, including Vista and 7, use the Windows Boot Manager to read the boot configuration files and data in order to load your Windows Desktop.
    If any of these files are corrupted or damaged, you will see a "BOOTMGR is missing" error. Fortunately, you can use a number of Windows tools to repair or replace the BOOTMGR or any related file that may be the cause of the problem.
    Insert your Windows installation CD disk in your computer's CD drive and restart the computer.
    Press "F8" repeatedly while the computer boots up.
    This command enters the "Advance boot options" screen.
    Select the "Repair my computer" option and then press "Enter."
    The System Recovery Options screen opens.
    Select the "Startup Repair" option at the top of the list and click "Next."
    The utility will scan your system for the cause of the BOOTMGR problem and repair it.
    Hope this helps
    Oct 30, 2012 | Microsoft Windows Vista Home Premium with...
    WINDOWS 7 LOADER
    Repair the Windows 7 OS with the Advance Boot Option. Press F8 key when starting Windows 7, then in the Advance Boot Option menu choose Repair Your Computer. Insert Windows 7 DVD in DVD drive to repair. then in the system recovery option choose Start Repair. follow the instructions there. After this the Windows will start normally.
    Sep 16, 2012 | Computers & Internet
    My acer aspire one kav60 fell and gives the options to start using safe mode,,safe mode with networking,,last known settings that workedq,, ect but restarts once it gets to the windows xp splash screen...
    Try to restart the system using " last known good configuration " option.
    If the problem persist you may have to restore the system to earlier restore point by starting the system in safe mode.
    hope this will help.
    With regards:
    Kartikey.
    Apr 14, 2011 | Acer Aspire One PC Notebook
    My dell c400 will not boot windows. it tries then goes to the screen to ask to boot in safe mode. will not boot in safe mode. run diagnostics and it passes everything. any ideas
    You need to repair your windows system files.
    For that you need windows disk recovery disk.
    If you don't have windows disk then buy it from nmearest computer shop.
    It is very useful for your computer life.
    Insert that disk into cd/dvd rom then when you power up the computer press F1 or F2 or del or ALT + F2 key to enter in bios .
    then go to boot menu and st first boot device as cd.dvd rom then save settings and exit.
    Then it boot from disk then follow the procedure and press any key to boot from cd..
    Then wait for 5 minutes then you can see scren to choose option choose R for enter in recovery console then type in prompt "chkdsk /r" then press enter.
    Then it fix and recover error on harddrive.
    Then restart computer and again boot with disk then this time choose R for repair previous windoiws then it repair old windows then you can get back your windows.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Jun 04, 2010 | Dell Latitude C400 Notebook
    What can i do to fix my volume boot on my laptop
    Best answer I can think of if you have a version of Windows installed is boot from the CD and use the Windows repair utility, Boot from the CD and press F8 as it boots then select repair installation.
    Nov 15, 2009 | Dell Latitude D600 Notebook
    Windows doesnt start
    you need to restore your boot system by booting from windows installation disk.
    whenyou boot fron CD and ask for repair , select install windows
    after you accept the disclaimer by pressing F8, installation will search for current windows installation
    after the search select RESTORE
    Mar 20, 2009 | HP Pavilion Media Center M9402f PC PC...
    HP Hewlett Packard 6910p 2.2GHz Intel Core 2 DUO T7500 2GB 160GB DVD+/-RW DL 14.1" WXGA WLAN BT Windows Xp Pro KR923...  PC Notebook Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
