Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Program light and 12:00 are flashing, no buttons work
I set up my Cuisinart Grind and Brew manually this morning. I got all the parts in place, water in the resevoir, etc., but the Program light just keeps flashing green and the time keeps flashing 12:00 no matter what I do. No buttons work no matter how long I press them, unplugging does not seem to affect the problem. I left it unplugged for five hours this morning. When I plugged it back in the Program light and the time 12:00 still just kept flashing in unison. Please help.
  • Anonymous Mar 24, 2009
    I have the exact same problem only the time flashes 4:00 instead of 12:00
  • Anonymous Apr 12, 2009
    I have a similar problem, but with mine its the On/Off button that is flashing and the display is 2:00. No combination of button presses/hold times seems to have any effect.
  • 8,596 Answers
Press program set once, then switch to clock mode to set time.
Posted on Dec 17, 2008
  • ldyblu66 Sep 03, 2011
    I tried this and it did not work now what please help I love my grind and brew.
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Water doesn't flow through DGB-900
You should download manual if you dont have it. I was having problems with mine read the manual and worked. I think you might have to program it like I did. I set the clock and then programed it for half and hour later and it worked. You have to program it when light is blinking and same for when you are setting the time.Hope that helps.
Apr 05, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind/brew 10 cup coffeemaker
The part the manual doesn't mention is that, after you have set the program time, you have to press the program button one more time. THEN, set it to auto-on. Also, make sure that the clock is set for AM/PM as appropriate - it will display PM if it is set for PM, and will not give an indication either way if it is set for AM.
Voila!
-Tha Mp3 Doctor
Feb 12, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
How to program to automatic brew
For most Grind and Brew's, you can press the PROG button or turn the dial to PROG, then press the HRS button to change the hour and minute to change the time. The led will display PM if it is set for PM, but will not display AM if it is set for AM. After you have finished programming, press the PROG button. Now activate the AUTO-ON button or slide the dial to the Auto-On position.
But, like the person said, we would need your exact model # to be more specific.
-Tha Mp3 Doctor
Dec 29, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Programming...
Yep. Press program again. Also, check am vs. pm. Enjoy!
Dec 15, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Won't brew any coffee
Press the program set button one more time to exit program mode.
Nov 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Need product Manual
Go to this link http://www.cuisinart.com/manuals/index.php?cat_id=3 There are a couple of different 10 cup G&B machines Hope you find what you need :)
Mar 30, 2007 | Cuisinart Grind and Brew, 10 cup, white
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
640 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
