Question about Makita 10" Miter Saw LS1030N
Replacing the saw blade
I took it apart and can't replace the spring on the cover guard.
  • Anonymous Nov 16, 2008
    i tried to change the blade on this saw and cant put it back together .
My husband had trouble replacing the spring that goes in the plastic safety cover....he just eliminated the spring and it works just fine...thankyou for responding....L Martinez
Posted on Sep 29, 2008
    Novelist:
  • 157 Answers
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble the spring on your saw. If not, use the contact information to speak to customer service and they should be able to assist. Hope this helps, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Posted on Apr 05, 2011
B & D #3051 worm drive saw: How do I access the return spring for blade guard?
Link,
Usually you will have to remove the blade guard to get access to that. There is usually a rubber stop with a screw going through it that you will have to remove, and a spiral spring clip on the inside of the hub of the blade guard that will also have to be removed and then you should be able to lift the blade guard off the saw. The spring will hook around the blade guard and the other end will hook to the saw housing. Hope this helps!
Apr 22, 2015 | Saws
When replacing blade spring for the safety cover fell out. Not surewhere it came from.
On most brands of circ saws, there will be a lug/tab on the back of the lower blade guard and also a hole or screw point on the upper inside of the main/fixed guard. The spring should have a hook at either end that will go on these fixing points.
Dec 14, 2014 | Saws
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 | Makita Saws
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
Makita
I don't have this particular model in my shop right now but almost all circular saws work like this. From the blade side of the saw, the spring attaches to a hole in the blade guard usually around the two to three o'clock position. With the blade guard correctly positioned on the saw, wrap the spring clockwise around the bottom of the hub and back up the nine o'clock side. There is another hole or tab inside the top of the upper blade guard somewhere around the twelve to two o'clock position. Hook the end of the spring there and test the guard for free movement throughout it's range of motion.
Aug 06, 2012 | Makita Bare-Tool BSS610Z 18-Volt LXT...
Replacing bar on husqvarna 340 saw. Appears to be a spring attached to guard that will not allow the guard to slide off. Does spring have a certain amount of tension and how is it removed so guard will...
Sounds like the blade brake is engaged. You should be able to pull the blade brake handle, located on top of the saw, in front of the top handle, back towards the handle to disengage it. You can find replacement bars, chains & sprockets for your saw at Partsbuggy.com.
Sep 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do...
if it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Oct 03, 2009 | Makita Saws
I am missing the part that brings the guard back when you lower the saw blade
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Sep 28, 2009 | Hand Tools
Makita 10" Miter Saw LS1030N Logo
489 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
