Question about Gateway 500GR PC Desktop
Thermal shut down on Gateway 500r
Hello Sir,
I received the thermal shut down message on a computer that is rarely used. I have kept it very clean and only added 2 gigs of memory. The fan has always run since purchase, never shutting down if the system was powered on. I assumed I needed another fan, put one in the expansion slots and the same thing happened. Now I have three running fans, and a computer that stays on for 5-10 minutes. Will the hard drive be destroyed, and is this system salvageable?
Thank you,
Jennifer
  • lightofjohn8 Sep 27, 2008
    Can you offer directions for an electronics junkie but technical dummy?
    President:
  • 1,952 Answers
Check ur heat sink in ur mother board processor
Posted on Sep 27, 2008
    Sergeant:
  • 264 Answers
Have you checked whether the CPU fan is working or not
  • 1 more comment
  • Sameer Kashyap Sep 27, 2008
    Thermal/overheating messages
    Given time to cool, the computer displays a warning message such as the following indicating that thermal or overheating event had occurred: The CPU was previously shutdown due to a thermal event (overheating)
    You also may hear four alternating beeps (high, low).
    Overheating warnings provide an indication that the temperature of computer's processor had reached an unsafe operating limit and the processor forced the computer to turn off. The audible tones and warning messages indicate that action is required to prevent future occurrences.
    Most likely it is the CPU Fan which may not be working and needs to be replaced.
    Hope this helps
    v\:* {behavior:url(#default#VML);}
    o\:* {behavior:url(#default#VML);}
    w\:* {behavior:url(#default#VML);}
    .shape {behavior:url(#default#VML);}
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Following are the two generic articles which you may refer to. These are not specific to your system.
    CPU Overheat
    CPU Errors
    Hope this helps
    All the Best
    The text did not appear correctly. Above i have provided two links which you may refer to, however these are not specific to your computer model.
Gateway intermittent shutdown
I installed a new alternater th battery is new
Dec 27, 2013 | Gateway MD2614u Notebook
Shut down
1) Computer dirty inside?
Air is used to cool the hardware components inside the computer.
If the Processor fan, and/or Heatsink is dirty, there is one of your problems.
The Thermal Paste on top of the Processor may have dried up too.
THOROUGHLY clean bottom of Heatsink, and top of Processor, then Properly apply new Thermal Paste.
2) What condition are the Radial Aluminum Electrolytic Capacitors, on the motherboard?
http://www.capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=oDGjWOabJ2E
http://www.hardwaresecrets.com/article/616
Post back in a Comment.
Regards,
joecoolvette
Dec 27, 2012 | Gateway HP 5188-8534 PAVILION A6110N...
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
My computer shut off by itself even though the battery was charged and the battery light kept blinking even after my computer was off. computer seems hotter than usual on bottom as well
It is probably shutting down to prevent thermal damage dut to overheating. Check that the fan is working. Even if it is, if the vents are clogged with dust the machine will not be able to cool properly. The only real remedy is to open the case, clean all the vents and fan, remove the heatsink, clean off old thermal paste and apply new paste before replacing the heatsink and putting back together.
Mar 14, 2012 | Sony VAIO VGN-S580B (VGNS580B03) PC...
I have a Gateway Profile 5.5 all-in-one PC. A few
Personally I'd try applying some more thermal paste to the top of the processor.
Jul 30, 2009 | Gateway Computers & Internet
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
My computer just seems to shut off, maybe it is overheating but the fans seem to be working.
if your computer is randomly keeps on shutting down this is a thermal issue which you need to address. check airvents, use compressed air to clean all possible obstructions between heatsink fan and processor. try avoiding blocking the airvent of your notebook. try also updating your bios
Jun 20, 2008 | Gateway Computers & Internet
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Gateway 500GR PC Desktop Logo
197 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
