Hitachi 50UX58B 50 in. Rear Projection Television
Problem for Hitachi 50UX58B 50 in. Rear Projection Television
50ux58b plug it in green leds power up & then go out
By wolfmann55 on Sep 27, 2008
when I plug the set in a series of green LEDs on main board power up then go out.
Best Solution
posted on Nov 07, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
had it repaired by service tech. was in the high voltage circuit. small part , & about 20 minutes time & he had me up & running for 240 bones. I'm sure it was a 50 cent part, oh well, it's a great picture.
Solution #2
posted on Nov 04, 2008
Not Rated)
gavincurtis
Rank: Guide
Rating: 0%, 0 votes
Working on a 60UX54B with identical problem (also has the same power supply as yours) which failed from power surge.
Can hear a quiet squealing sound when plugged in for about 2-3 seconds illuminating 6 of the 8 green power monitoring LEDs, actually powering up high voltage and audio and then shuts down. No other activity or response from power button or remote. +5VDC and +9VDC LEDs remain dark as no powerup command is sent by TV CPU which is normal. +12V standby LED does illuminate and then turns off with rest of LEDs. Is this +12V standby LED supposed to remain on at all times?
Red 'protect' LED illuminates dimly during this brief power-up time, gets bright and then intermittently flashes (very dimly) of all things after shutdown. There is no flash diagnostic feature for this LED. Vcc (pin 5) of PWM controller (I901) on PCB fluctuates between 14-21 VDC in sync with flashing of red "protect" LED.
No shorts or excessive loads in other parts of TV because no difference when power PCB is disconnected from the audio/tuner PCB. Still powers up for 2-3 seconds when plugged in and then off. LED's stay on much longer as there is no loads on power supply other than the LED's themselves.
All IC protectors test good.
So now I suspect STR-6811A (I901) PWM controller is at fault and it would indeed be damaged by a power surge. This is the 7 pin IC on the large heatsink near the switching power supply transformer where AC cord connects.
Ordered a replacement STR-6811A on ebay ($12.00 with shipping) and will update here if it solved my problem.
Was this helpful?
Yes
No
Solution #3
posted on Sep 27, 2008
Not Rated)
Ronnieh49
Rank: Wiz  Hitachi Expert
Rating: 82%, 1588 votes
bad power supply
Was this helpful?
Yes
No
Popular Solutions for Hitachi 50UX58B 50 in. Rear
Questions and Unsolved Problems for Hitachi 50UX58B 50 in. Rear
Do you recommend Hitachi 50UX58B 50 in. Rear Projection Television?
Answer
Answer
I turn on my Hitachi ultravision tv and get no sound. I checked the mute button, turned it off. And... (More)
Answer
wwood51375 yes those components can also affect the color. I tried answering your question but they... (More)
Answer
screen has a double image. looks like the green gun is bowed at the top and bottem of the screen.... (More)
Answer
50ux58b had lost poewr, red light went out never came back on
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Surprise, AZ
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
