Question about Maytag Performa PAV2200
Washing machine will not fill with water maytap performa - will not fill w/ water - keeps running. Solutions?
  • rbreeding7 Sep 29, 2008
    Fixed the problem by simply raising the drain hose even with top of machine - simple fix! Thanks for the input.
  • Jspiddlin Oct 06, 2008
    Cold water, warm water, hot water...will just not fill. Help!
    Genius:
  • 1,122 Answers
Water valve on back bad?try it on cold then cold warn then hot and see if you get anytihing,let me know more-mike
Posted on Sep 27, 2008
  • Mark Kraner
    Mark Kraner May 10, 2014
    I have the issue that the cold is very slow filling. I checked the water source and have plenty of waterr pressure. Hot water works fine.
My washer fills with water and keeps filling doesn't stop on the selected water level for the load. It doesn't wash because the water keeps filling. What's wrong with my washer? Help please (Maytag...
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
Jan 07, 2011 | Maytag PAV2300 Top Load Washer
The washer keeps filling and won't stop. Sometimes can get it to stop on the wash cycle but won't stop filling at all on the rinse cycle. Any solutions?
I get this question a lot. Washer is flooding the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose. Look at this diagram: water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
Sep 12, 2009 | Maytag Performa PAV2200
Magtag Performa washing machine water does not stop filling
there are a couple of sensors on the rear of the drum, it is probably one or both faulty , telling the copmuter that there is no water in it. or a loose wire.
Apr 26, 2009 | Maytag Performa PAV3200
Maytag washer performa is over filling with water.
Bad water level switch or pinched hose going to water level switch.
Feb 21, 2009 | Maytag Performa PAV2200
Maytag performa washing machine
yes im a expert (laugh)...your drain hose is to low..the drain hose must go up the height of the unit abut 3 feet before it can go down...now if you have your drain hose connect directly to your drain pipe ,,the waste pipe will **** the in coming water right out of unit,,we call this a sphion effect...booth easy fixs,,,onthejob
Jan 22, 2009 | Maytag Performa PAV2200
I have a 4 year old Maytag Performa washing machine. Regardless
Hi!!! You seem to have a bad water level switch..If you turn on the water and water just fills in and doesn't stop then you have a bad water level switch..If you just turn it on and water enters then you have a bad water valve..Good luck..
Jan 03, 2009 | Maytag Washing Machines
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
My washer just keeps trying to fill
check the height of the drain hose. if you aren't seeing a leak on the floor the drain hose might be below the height of the tub. the water always seeks the lowest level and if the hose is too low the water wwill run right out
Jul 27, 2007 | Maytag Performa PAV2200
Maytag performa washer hot water runs continuously
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
