Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
FRIGIDAIRE DISHWASHER FDB1050REC0 LEAKS UNDERNEATH
When dishwasher is started, after it fills for about 10 seconds, then water start dripping from around one of the two brass threaded plugs in the bottom of the dishwasher, this brass plug has a red wire attached to it.
  • 1 more comment
  • Anonymous Sep 29, 2008
    I have the same problem... mine is 3 yrs. old.  Just had the plumber take
    a look at it and he said "good luck" with trying to repair it.  Might have
    to buy a whole new one.  Not going to buy another Frigidaire.
    Forgot to say that the plumber figured it was dripping from the heat
    element.  Costly diagnosis...
  • dmann73702 Nov 23, 2008
    My dishwasher leaks underneath about in the middle of the unit. After the first load was washed I noticed suds in the bottom of the tub. Maybe a soap issue. I will keep testing
  • 750 Answers
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
Posted on Oct 03, 2008
How do I clean dishwasher its starting to leave whiet spots on dishes
Good Afternoon Friend,
I understand you want to know how to clean your Frigidaire dishwasher, model# PLD2560LCC, as it is starting to leave white spots on your dishes. Please follow these simple instructions:
1. Load your clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes). The SENSING light will be off.
5. Unlatch and open the door and pour 2 cups of white vinegar into the bottom of your dishwasher.
6. Close and latch the door and allow cycle to finish.
Note: If these conditions persist, a home water softener should be considered.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
New frigidaire dishwasher won't fill with water
Make sure that your water is turned on under the sink from the line tapped off of the hot water pipe if it is on pour 3 large pots of water in the bottom and hit start
May 10, 2014 | Frigidaire FFBD2406NS Full Console...
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Dishlex Global 300 Dishwasher - ECO Light flashing - Manual indicates incorrect fill level - Manual suggests hold ECO button for 10 Seconds. No success. Have tried pressing and holding buttons - no...
eco light sometimes indicates that water has got into the bottom panel of the machine. A float switch is underneath to protect the machine ( and your kitchen floor from being flooded. ( Either from overfilling or a leak) If you tilt the machine backwards see if any water runs out. If the machine restarts , then you will have sourced the problem. Should the flashing start again later, you may have a water leak underneath. Also check the lower door gasket to make sure its clean. If the gasket is dirty, sometimes water builds up behind the gasket and drips over the front of the tub into the bottom panel underneath causing this symptom. When cleaning the gasket, be very carefull!! The edges of the door at the bottom are razor sharp..
Jul 26, 2011 | Dishwashers
I have a Frigidaire dishwasher that is beginning to leak from the bottom. After taking off the lower front floor panel and looking under the unit, then pouring a bowl of water into the washer the water...
Hello Mileshjr,
I don't disagree... Nice looking unit...
What you have to do is assess the LEAK(s)...
and do a cost/benefit analysis...
If indeed the parts are available (they seem to be)
http://www.appliancepartspros.com/motor-pump-parts-for-frigidaire-fdb1050rec0.html
Then all you have to do is find the cause of the
LEAKS and repair them...
Mine turned to be rusted body panels...
(not much you can do there... Unless you
find a complete DONOR... Not unlike restoring cars...
(the labor of love)...
Check out other part houses...
Repair-clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Part-Select
PartSelect Appliance Parts and Repair Help
... and don't forget to check eBay.
I will confess the new PRO Series "QUIET" models
are VERY quiet... and sooo... pretty I had to REMODEL
the ENTIRE KITCHEN... (no savings there).
Hope this saves $$$$
Carnac the Magnificent
Jan 14, 2018 | Frigidaire 24 in. FDB1050REC Stainless...
We have a neff dishwasher and the pump is draining all the time (even when the door is open) but there is no water in the dishwasher. Is there a way to stop the pump and reset the setting for the flood...
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
It seems that not enough water gets into the washer.
The only thing that could really cause the dishwasher to not get enough water would be a dirty screen on your water valve, as dishwashers are strictly a "time fill", noramly 90 seconds fill time. Remove your water line underneath (shut off water first), remove teh brass elbow, and check screen
Mar 28, 2010 | Frigidaire Dishwashers
Maytag MDBH950AWB Leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
zgwerty
Feb 23, 2009 | Maytag 24 in. MDBH950AW Built-in...
Dishwasher leaks
Sound like the fill valve is not working. I woudl check the hoze for a clogged screen ,then replace the fill valve if no clogs found.
Jan 06, 2009 | Kenmore Dishwashers
This is a simple solution, the brass nut that connects the heating element to the base of the dishwasher is cracked and needs replaced. It takes just a few minutes to replace, just remove the nut after TURNING OFF THE POWER and take to your local parts store, they should have one in stock. You might have your model number with you. Appldoc
Oct 31, 2007 | Dishwashers
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
1,482 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
