Question about Corel WordPerfect Office 12 Standard Edition for PC
Changing the color of my screen display
I added a toolbar and inadvertently changed the color of my screen background to blue. Type is now white, as is the cursor. How do I cange it back?
Thanks!
How do i change my blue screen back to normal
Posted on Oct 11, 2008
Must change orientation on Paperwhite from landscape to portrait; how?
When reading a book, you can access useful features by tapping the top of the screen to display the toolbar and then tapping the Menu icon.
  • Landscape Mode: Change the orientation of the page from portrait to landscape mode.
  • Not all books / authors allow changing view.
Nov 11, 2014 | Amazon Kindle Paperwhite
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
Aug 30, 2013 | Computers & Internet
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
Does anyone know why my mic doesn't work and my desktop background doesn't show?
If you have Windows 7 Starter then you are limited on changing the background.
Jun 09, 2012 | Computers & Internet
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Hi how do i put a backround on my phone
Hello edgar_25_06,
Putting a background on the palm centro phone could either mean adding a background picture or changing the background color. If changing the color is is desired then its simple:
•Select the the 'System' category in the drop down menu at the top of the main screen.
•Open the Prefs application.
•Select 'Color theme' (near the bottom of the Prefs options).
The Color theme option displays a list of many different screen color settings. Each one of the color themes can be selected and tested on the centro until you find the one you like. Adding a picture for a background is a different matter. I haven't found out how to do that yet.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 18, 2009 | Palm Treo 500 Centro
Display background color
Check your MS Windows System colors
Most likely that is the cause of the problem.
Sep 29, 2008 | Corel WordPerfect Office 12 Standard...
Adobe acrobat checker board like watermark
If you see a grey and white 'checkerboard' background, you're seeing the background designed to show you the transparency of items in your document.
Select: Edit > Preferences > Page Display then un-check: "Show Transparency Grid."
Jun 08, 2008 | Adobe Computers & Internet
My type tools does not work.
Perhaps you've got the text color set to the same color as your background (both white). With the text tool selected, left-click on your document once, then left-click on the 'set the text color' box in your toolbar. Choose a color that is dark enough to show up in your screen. Make sure your text size is large enough to show at your current screen resolution.
May 29, 2008 | Adobe Photoshop CS2 for PC
Blue out of focus; casting blue "glow"
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
Corel WordPerfect Office 12 Standard Edition for PC Logo
302 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
