Question about Epson Perfection 4490 Office Flatbed Scanner
Epson 4490 There is a Grinding sound when I scan
Hi, I have a epson 4490 scanner. I have used it maybe 100 times. The last few times that I have scanned with it I hear a loud grinding sound. It still scans okay. Should I be worried? Is there something I can do to fix it?
  • 3 more comments
  • Anonymous Dec 16, 2008
    my epson scanner makes a terrible grinding noise.  It won't scan.  I have turned it off and on/switched both locking devices off and on 5 and 3 times and it still sounds bad and won't scan.  Help!
  • HardwareHeck Jan 21, 2009
    Same problem here.
    One workaround is simply to let it stay powered on all time. This terrible sound occurs only seconds after power on.
  • 4bornot4b Jan 25, 2009
    Thanks, I checked the lock switch and is was set to unlocked.
  • 4bornot4b Feb 04, 2009
    I did further investigation and what happens is as the scanning head moves across the glass it is stopping between the B5 and LTR paper positions that are marked on the scanning bed. The Head stops moving but the motor is still trying to move the head to the end of the glass where it is marked MAX/A4. Any ideas?
    Thanks
  • YadaDoydoy May 07, 2009
    Epson products are junk. I have the same problem on my 4490, grinding.Both locks are off.  Now it wont even do anything. Had the same problem on a previous Epson Scanner, and I have an R1800 printer that is the worst problem child I've ever had.i waste so much time getting these damn things to work I could just take my work to a shop and have it done cheaper time wise.  Epson makes crappy products at premium prices, and I will never purchase from them again.
Check the lock position underneath your lid-located in lower right corner. The lock on the transperancy unit tranportation needs to be unlocked (moved to the right).
Posted on Dec 08, 2008
I tought my scanner was dying. In the modern computer worl, we often say that the failure is to be found somewhere in the front of the screen. This case too.
The lock button under it's cover was set in LOCK mode. I didn't guess that myself (embarassed now, yes).
Posted on Jan 22, 2009
I have a new Epson perfection 4490 photo scanner. I moved and can not find the CD that came with this unit. I never used it and can not find a copy of the CD to download. I would purchase one but live on...
Hi Ray,
You can download the drivers from Epson at this link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Downloads&oid=58611&prodoid=53540925&category=Products
You need the Scanner Driver and Epson Scan Utility; the one at the top of the page is for Windows 7
Scroll down for Vista & XP version.
Sam
Sep 08, 2010 | Epson Perfection 4490 Film / Flatbed...
Epson problem
Here is the download page
http://www.epson.co.uk/Store/Scanners/Epson-Perfection-4490-Photo/Drivers-Support?supportLandingPage=true
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
Epson 4490 scans with colour streaks/ digital interference
did you properly close the scanner lid? these type of errors do usually occur when you unproperly close the lid wherein light passes inside causing it to reflect on the document that you are trying to scan
Sep 13, 2009 | Epson Perfection 4490 Film / Flatbed...
Unable to open Epson Scan in 4490
try to uninstall and reinstall your printer software
Jul 17, 2009 | Epson Perfection 4490 Film / Flatbed...
I have escndv.exe error problem with 4490 scanner. I've reinstalled the drivers and it still comes up
The first thing to try is uninstall the Epson Scan. Via either the start
menu item if one exits or from the Control Panel Add/Remove Programs.
Reboot computer.
Install the latest driver from the epson web site -
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=50666&infoType=Overview
Latest is 2.68A for WindowsXP, etc.
You should go ahead and download a fresh copy from the web, your copy may be
corrupted.
After the install, reboot.
If that does not solve the problem.
You got to go deeper.
Remove the Epson scan. (again).
Backup your registry.
Edit the registry and remove all references to the Epson Scan.
Remove the folders and entries for Epson Scan in \Windows\Twain_32\
Reboot:
Install Epson scan.
Good Luck!!
Jul 03, 2009 | Epson Perfection 4490 Photo Scanner...
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
I have just bought an Epson 4490 flatbed scanner and want an owner user manual as this is a new machine and there was no real instructions on how to operate the Epson 4490
Here's the Epson Support page for your scanner. Just click on the Manuals and Documentation link for all the available information about the 4490:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
It's possible that the Tutorials and the FAQs will be more useful to you..
Fixya!
Chris (ziraffa)
Jan 11, 2009 | Epson Perfection 4490 Office Flatbed...
EPSON Scanner 4490 Problem
So you've completely ininstalled. Now you should download and install nCleaner, and do a Clean System, and then a Clean Registry. Now:
Download and install the latest 4490 driver software from here:
The Epson Copy Factory Update may be of some use to you also.
Hope this helps
Chris (ziraffa)
Dec 08, 2008 | Epson Perfection 4490 Office Flatbed...
Epson Perfection 4490 Office Flatbed Scanner Logo
751 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
