Red line running through tv when it is on - Televison & Video
  • gaztree Oct 30, 2008
    red line runs down the left side of tv when its on, this comes and goes.My son uses his xbox 360 on the tv sometimes could this have anything to do with the problem.
Your front panel is shot. This is a serious problem for your set and you, if you do not have warranty. This can be very pricey to have fixed, because of the cost of the part. At our shop I have seen some manufacturers with some sets just have the whole TV replaced because in there eyes it was just as cost effective to replace the whole set under warranty.The front panel or display is the most expensive part on the new TV's. Sorry I'm sure you did not want to read this. Get a second opinion, I hope I am wrong in this case.
Posted on Sep 27, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Tv takes up to four minutes to turn on and when it does it has distorted red lines running verticaly across the screen
is there retrace line with red colour then off agian.if yes there is red gun problem which is shorted with ground.you have to do give another way heater ac voltages or replace picture tube.
Oct 16, 2010 | Samsung Televison & Video
Red area/red line on tv screen
Odds are it is your convergence chips! If you have any colors out of alignment, thats what it is. Also if you had a speaker too close to the Tv it can cause colors to shift. There should only be 1 mirror. IT would have NOTHING to do with your problem. If you are only have problems with the red, just replace the one STK chip. They run about $20-30 on ebay. $5-10 if you buy china made. Usually the cheap ones dont get along with sony.
Dec 09, 2009 | Sony KP-51HW40 51" Rear Projection...
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Jun 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I can't get my coby DVD 937 to play sound while watching tv. It works fine while playing a DVD or CD????
there should be an input line of just audio cable hookups (one red and one white) that you have to run and an output cable from your tv audio output of just red and white. make sure the tv says output or line out and the surround sound system says input or line in
May 05, 2009 | Coby DVD-937 5.1 Channel DVD...
Picture turned red then tv turns off
The red picture tube is bad, you must replace before it cause damage to the boards.
Feb 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Red Lines
Red convergence IC defective===Replace Stk392-040 IC's.
Change both for reliability.I use Panasonic brand with no recalls.
let me know how it goes....T.
Oct 23, 2007 | Samsung HCL552W 55" Rear Projection...
Red lines taking over my T,V
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 26, 2006 | Samsung HCM5525W 55" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
