Question about Sanyo DP42746 42 in. Plasma Television
Red line running through tv screen when tv is on
  • chadeosgurl1 Jan 09, 2009
    i have a few black lines in the middle of my scrren on a 42" plasma is there any solution for the discolorment
I had the same with my SANYO 42 inch plasma DP42746 with red lines that were blinking and looked something like an EKG monitor. I had sound for awhile but without the picture, it is hard to determine if I had inadvertantly muted the system. WE had this SANYO for 39 months and it worked fine until them. Does it sound like drivers.
Posted on Mar 18, 2010
  • Sanyo Master
  • 5,568 Answers
The individual dots (pixels) that make up the picture are controlled by vertical and horizontal drivers that are rapidly switched off and on. They are arranged as columns and rows with these further controlled in time in a synchronized fashion. The line is being caused by a driver that is failing.
Depending on the degree of integration, these final integrated circuits may be part of the display and not individually replaceable by hand. You may only have the option of replacing the screen with the failed part.
It will be necessary to contact Sanyo (who may not have manufactured the set) to find whether the repair is cost effective.
Posted on Oct 01, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Mar 26, 2014 | Sony KD-27FS170 27-Inch FD Trinitron WEGA...
Tv takes up to four minutes to turn on and when it does it has distorted red lines running verticaly across the screen
is there retrace line with red colour then off agian.if yes there is red gun problem which is shorted with ground.you have to do give another way heater ac voltages or replace picture tube.
Oct 16, 2010 | Samsung Televison & Video
Red line running from the top to bottom of the screen
there is a lcd panel problum means not removable only the solution is to chang the lcd panel
Jan 26, 2010 | Vizio VA220E LCD TV
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Lines running vertical that appear to be red
hi
it is colour wheel problem,,,check it
please rate it..
thank u....
Jul 04, 2009 | Televison & Video
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Jun 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture turned red then tv turns off
The red picture tube is bad, you must replace before it cause damage to the boards.
Feb 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Red Lines on Screen
Dave, HMMMM Dual pictures This is a problem that every projection TV runs into at least once or twice in its lifetime. Its the old convergence IC falure thingy. These IC's go bad and should be replace all at once. These are not consumer replaceable unless you have had training in the electronics or TV repair fields. Please call out a pro to assist you with this repair as A TV is not the place to experiment in because of the HI voltage and saftey issues. Good Luck
Jul 29, 2006 | Hitachi 53SDX89B 53" Rear Projection...
Sanyo DP42746 42 in. Plasma Television Logo
227 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
