Question about Denon AVR-1706 Receiver
Denon AVR 1706 reciever
I have had this reciever for 3 yrs and has worked perfectly until this morning tried turning in on and I cannot get any power, lights etc. Any Ideas? Do these recievers have breakers or such?
  • t_mele Dec 28, 2008
    I too, went to turn on my Denon AVR 1706 and nothing happened. I pushed the standby button (it was circled in red) and the unit shut down. I have not been able to turn it back on or get any semblance of power to the unit.
  • talrash May 08, 2009
    AVR-1706 after three year would not turn on
  • 27 Answers
It a control switch and power supply that needs to be replaced they have blown.
get in contact with me so I can help you financially...I can buy your unit for parts.
It will cost more than the unit
radricktip@gmail.com
Posted on Nov 11, 2008
How do I connect my computer to denon avr-1706
Depends on your computer's sound capabilities. At a minimum you could use its analog headphone and microphone jacks as Output and Input, respectively and run them to a Tape loop on the receiver.
If you have compatible digital audio ports on your PC, conenct them to their respective corresponding outs and ins on the Receiver.
May 01, 2010 | Denon AVR-1706 Receiver
My denon avr-1706 is going into protection mode immediately after turning on. whats the problem?
You either have an overloaded output or a shorted powersupply. If you have verified that your connections are not the cause then the problem is internal and will require service from a trained technician. Switching power supplies are notorious for going bad. Two of the main components are the FETs used for switching and the PWM generator.
Feb 09, 2010 | Denon AVR-1706 Receiver
Denon AVR 1706 Powers on display then shuts off lght blinks red
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Jul 29, 2009 | Denon PMA-2000R 2-Channel Amplifier
Denon AVR-1706 Left Front and Rear speakers stopped working. Any suggestions?
go into the settings menu and do a sound test using the recievers pink noise tester to test each speaker connected, if while doing this test you still get no sound from those two speakers check connections, make sure speakers are not blown.
if speakers and connections are good then the reciever needs repair
Jul 18, 2009 | Denon AVR-1706 Receiver
1706 Red ring of death
Check all your speaker connections to make sure none have shorted out.
It appears the protector circuit is being activated upon startup. cut the power altogether to the unit before checking it.
Mar 26, 2009 | Denon AVR-1706 Receiver
Sound problems
try to introduce your speaker one by one and check every time you enter the speaker check for bad cable(internel short)open cable cover and touching of adjacent cables together.-try to change the position of your speakers.
Jul 12, 2008 | Denon AVR-1706 Receiver
Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Jan 10, 2007 | Denon AVR-1706 Receiver
No system setup menu on screen
its related to the control AVI switch inside on the right side with the contact and 7 Ri sisters.
about 200.00 something to repair.
I can help with some money do you have the reciever still???
Jan 04, 2007 | Denon AVR-1706 Receiver
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Denon AVR-1706 Receiver Logo
255 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
