Question about Vacuums
Lost suction - Hoover Wind Tunnel S3630
The vaccumm has lost its suctions. The indicator says the bag is full even though its a new bag.
    Novelist:
  • 97 Answers
You have a clog. The "bag full" indicator is nothing but a vacuum gauge, and impeding the airflow will cause a false indication of a full bag.
Clear your hoses and the air pathways behind the brushroll, and you will be back in business.
-R
Posted on Sep 27, 2008
Why is my hoover wind tunnel blowing out side filter and not suctioning
Perhaps dirt or hair is stuck or the full canister needs to be emptied, remove blockage and suction should return.
Jul 15, 2014 | Vacuums
There is too much suction even with the hand tools on Hoover wind tunnel. Can i adjust suction somehow?
Hi, it's Jeremy from Crucial Vacuum.
If there is too much suction, adjust the nozzle control knob to a higher setting. The knob is located on the front of the vacuum at the bottom. For optimal cleaning efficiency a low setting should be used for most types of carpet and for hardwood floors, tile, and deep carpets use a higher setting.
You can purchase direct all of your replacement filters, bags, and accessories for your Hoover vacuum from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 17, 2014 | Hoover Self-Propelled WindTunnel Bagless...
No suction
I have found more vacuums on the way to the dump because they were full. Check. Is it full?
If not the air way is clogged.
May 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Hoover Wind tunnel supreme, loss of suction
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40600&thid=562967
posted by bazballfan on May 01, 2008
Hello, I purchased two of these models in late 2007 and after changing the bags on each of them I have little to no suction with the vacuum. The hose is fine and I have taken them apart and there is no obstruction in the hose or in the base.
These worked so well and now they don't do anything. The bag isn't filling much and the simplest things can’t be vacuumed up
Please help me to fix this
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U5450-900 Windtunnel Supreme Vacuum
Sorry you are having a problem, it sounds lie you have done almost everything, but just in review it could be some of these problems:
Belt change – every 4 to 6 months
Are the brushes in good shape
Where does your suction drop off
Is the bottom plate securely on the bottom
Are there any gaskets that are broken or leaking
Is the bag installed securely
Did you check for any clogs or obstructions
Is the filter clean
Feel free to contact your local vac dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Wind tunnel hoover
Do you have suction at the hose end, if you do then it may be clogged at the inlet by the brush roll. Is the filter cartridge clean? If it is clogged and air can't pass thru it, then you will have no or low suction. Might also check the belt to make sure it is turning.
Nov 30, 2007 | Hoover U5753-900 WindTunnel Bagless...
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
246 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
