SOURCE: My 1994 Mitsubishi Lancer (4g15) engine stops
Fuel pump
Testimonial: "It's the fuel pump indeed. Also the gas tank found to be very dirty. The fuel pump was replaced, fuel system cleaned, now the car runs perfectly."
SOURCE: 1994 Mitsubishi Lancer 12valve 4g15
I have a 1994 1.5 litre Mitsubishi Lancer with a 12 valve engine. Located to the right of the rocker cover is the distributor and coil assembly. I have to replace the coil because the old one died. I can remove everything with ease except for a small spring loaded plate that appears to have been pressed onto the shaft. How can I remove that plate without damaging the shaft so that I can replace the coil?
