Question about Mitsubishi WS-55511 55" Rear Projection Television
Inputs on the front of the tv
How do you tell the tv to get its input from them?
  • 927 Answers
Good Day;
Use the TV's remote and push the input buttom. Good Luck, big IRISH.
Posted on Sep 30, 2008
I need to know how to set up my tv's input I have no button on the tv to change the input but If anyone knows how I can get to it pleas help
There are two flip up doors on your TV at the front. Open the doors and look for INPUT or use the channel button and go all the way down to the lowest channel and go one or two channels past that channel and you should see the INPUT with your Wii connected to it. Be sure to have the Wii on while searching...
Mar 09, 2013 | Televison & Video
Front panel switches and inputs disabled
Yes it is, it is, after all it is an input. Here is the owner's manual that should tell you how to reset:
tv.manualsonline.com/manuals/mfg/olevia/olevia_flat_panel_telev
Jan 13, 2013 | Olevia 32" 232v 1080i widescreen lcd hdtv...
Change input without remote
from what I can tell in all the pictures is maybe the channel changer on the front look for the input front or back. it should have it's own channel. if not then you need the remote
Sep 07, 2012 | Sansui DTV2760 27" TV
My sanyo was working fine, then a child hit a button and now it says no input signal sources could be located how do I fix this
The TV has different inputs modes, the TV tuner being on of them, another mode(s) will accept an input from the input jack(s) on the back, front or side of your TV. Look for and source button or input button on the front of the TV, press it waiting a few seconds between each push until the picture returns.
Jun 19, 2010 | Sanyo DS27910 27" TV
Video inputs not working
Looks like your son got into the service menu,(it`s rare since you need a specific combination of keys to get into it) and somehow managed to disable one of the input.I can`t tell you how to get back into it since it could do you more harm than good but any local tv repairman should be able fix that in five minutes.
Oct 30, 2009 | Sharp 27K-S100 TV
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Connecting vcr to tv
Find Video & Audio Out pins at back of Combo player. This is output signal which will be connected at Video & Audio Input at front of TV. Watch out video pin will go to video input. Now select AV input of TV by remote. Usually its AV-4.
Have fun, or need more info, let me know the out comes.
Oct 22, 2008 | RCA VR546 S-VHS VCR
RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Dec 17, 2007 | RCA F32650 32" TV
Video Input
If your remote has a WHO*INPUT buton, that should allow you to select the front input.
Dec 29, 2006 | RCA F32649 32" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
