Problem for Jenn-Air Dishwashers
Generic problem for all Jenn-Air Dishwashers
Front Glass Door Panel on Jenn-Air JDB...
Hello, the glass panel that is mounted on the door of the subject Jenn-Air dishwasher is no longer attached to the small brackets (flanges) that hold it on the inside. We have it taped the glass panel to the door so that it won't fall onto the floor.
It appears that the black rubber-like adhesive that is (was) between the glass panel and the small brackets (flanges) has let go. We don't need the metal brackets; we need the black adhesive to reapply the glass panel to the brackets. Can you help identify what the black adhesive is so that we can order it?
Comments:
Sep 29, 2008
- Thank you for your suggestions! We think that liquid nails would be too permanent, so I'm wondering if you can suggest an adhesive that would 1) not react adversely with the white paint on the glass panel 2) would not dissolve the black rubber-like adhesive (which has let go) that's between the glass panel and the small brackets, and 3) would be strong enough to hold the glass panel, which is where the DW handle/pull is located, and which is subject to stress caused by constant opening and closing.
Thanking you in advance.
Oct 05, 2008
- Ok, Harvey, we took your suggestion and got some E-6000 industrial strength craft adhesive from Eclectic Products, Inc. We'll try it tomorrow and I'll let you know how we make out with it. Thank you for your time and suggestions.
Solution #1
posted on Oct 01, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
Hi again,
You think that liquid nails would be too permanent, so you're wondering if I can suggest an adhesive that would 1) not react adversely with the white paint on the glass panel 2) would not dissolve the black rubber-like adhesive (which has let go) that's between the glass panel and the small brackets, and 3) would be strong enough to hold the glass panel, which is where the DW handle/pull is located, and which is subject to stress caused by constant opening and closing.
Different adhesives are available in diferent parts of the country and they are all subject to proper instalation. So I'm going to sugest some guide lines. 1) You're going to have to do a little leg work. You're going to talk to different people in different hardware stores telling them about your three requirements. You'll be surprised at the varying degrees of knowledge. Don't argue, just take notes. 2) Once you've settled on a product it's time to test it. Find a small piece of glass and aply it to metal useing the adhesive. After drying you can tell if it is satisfactory. If not go back to no.1.
3) Once you're happy with the test find a pair of C-clamps and two blocks of wood. Aply adhesive, then using the wood blocks to protect the glass use the C-clamps on each side. Be carefull not to overtighten. Do this with the door horizontally. Just watch the adhesive, when it starts to squeeze out, stop. Make sure the clamps are aplyed evenly. Be carefull. Good luck.
Harvey
Solution #2
posted on Sep 28, 2008
Rank: Guru
Expert
Rating: 87%, 188 votes
Hi Fairhill,
I'm Harvey the Master Plumber.
Your question is: It appears that the black rubber-like adhesive that is (was) between the glass panel and the small brackets (flanges) has let go. You don't need the metal brackets; you need the black adhesive to reapply the glass panel to the brackets. Can you help identify what the black adhesive is so that we can order it?
Any good adhesive will work. If you're never going to remove the glass panel then use liquiod nails allowing 24 hrs for drying time. If you might want to remove at a later date then any adhesive that remains plyable will work.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Popular Solutions for Dishwashers
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
2 Solutions
Jenn-Air 24 in. JDB1100AW Built-in Dishwasher
1 Solution
Jenn-Air 24 in. JDB1250 Built-in Dishwasher
1 Solution
Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher
1 Solution
Questions and Unsolved Problems for Dishwashers
Buying a used dishwasher Maytag MDBTT70AWB anything I should know about this dishwasher
Maytag dishwasher MDBTT70AWB anything I should know about the machine. Any trouble shooting...
(More)
Maytag dishwasher MDBTT70AWB anything I should know about the machine. Any trouble shooting problems.
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out...
(More)
13 year old daughter put liquid dishwashing soap in the rinse dispenser. Now all dishes come out covered in soap scum. How do I get liquid dishwashing soap out of the rinse dispenser?
circuit breaker flipped. Where is the reset button on my Kenmore ultra quietwash 4
maytag series 100 dishwasher has water in bottom after cycle completed this problem has just started
