ACUSTIC RESEARCH gold cable end came off my cable and exposed the wires . is it under warentee ? STEVE LIMANEK ACS340TX@AOL.COM
  • 31 Answers
You'll have to check the length of the warranty on the card, and compare that against the receipt from when you bought the cables. If you don't have the receipt, they may or may not honor a warranty claim.
Posted on Sep 27, 2008
F1 light keeps coming on
Hi Alan, it should be noted that the reasons EFI lights constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets. For more information about your issue please visit the websites below. Good luck and have a nice day.
http://fullmanuals.com/search/?q=2002+Honda+GL+1800+Gold+Wing
Sep 06, 2015 | Motorcycles
How do i replace the end of an electrical cord that has been cut off
Purchase a new 3 conductor End - Note*** Connection procedure will be the same for either the Female or Male end...
  • Carefully cut around the sheathing being mindful to not cut into the individual wires sheathing.
  • Then peel away about 1.5", exposing 3 individual wires
  • Now, strip back about .50" of sheathing from each wire
  • Twist bare wires so individual strands are tight
  • Separate the cord end (many different varieties) and insert wires into a hole, securing nut, etc, to bring into proximity of connection lugs.
    • Black wire onto 'Gold' screw
    • White wire onto 'Silver' screw
    • Green wire onto 'Green' screw
  • Reattach in reverse order
May 30, 2015 | Generic 50ft 163 300 Volt Extention...
I have used my fnlamp@aol.com as my email address from the beginning! My wife also has signed in under her email,but I want mine back as I am A Lifetime Gold Elite Member. #670 633 524 Can you assis
What website/service are you trying to sign in to? What error message are you getting when you try to sign in? Have you tried using the site's 'forgot my password' option? More information needed before anyone can help you.
Jan 28, 2015 | Computers & Internet
Where do i plug in the power adaptor, so I dont have to worry about using the choke when the bike gets cold?
Instructions
    • 1 Fotolia.com"> install-motorcycle-cigarette-lighter-1.1-800x800.jpg If the battery is installed under the seat, loosen and remove the hex bolts holding the seat in place, and remove the seat from the motorcycle. If the battery is mounted under a side battery cover, pry the battery cover from the motorcycle to expose the battery.
    • 2 Strip one-half inch of insulation from one end of the black wire and one end of the red wire. Place a ring terminal over the stripped ends of the black and red wires, and crimp the terminals to the respective wires.
    • 3 Place the positive wire from the weatherproof socket into one of the holes in the first splice connector. Place the free end of the red wire into the splice connector, and crimp the connector to make the electrical connection.
    • 4 Place the negative wire from the weatherproof socket into one of the holes in the second splice connector. Place the free end of the black wire into the splice connector, and crimp the connector to make the electrical connection.
    • 5 Loosen and remove the retaining nut on the positive battery terminal. Place the ring terminal attached to the red wire over the terminal screw, and replace and tighten the positive battery terminal retaining nut. Loosen and remove the retaining nut on the negative battery terminal. Place the ring terminal attached to the black wire over the terminal screw, and replace and tighten the negative battery terminal retaining nut.
    • 6 Route the power outlet to a point on the frame below the rider, and attach the outlet to the motorcycle frame using a cable tie. Use the remaining cable ties to attach the excess wire length to the frame of the motorcycle. Reinstall the battery cover or the seat when finished.
Instructions
Instructions
rate these after reading
Jan 16, 2013 | Motorcycles
How do I connect my acoustic research 200 to the computer then to the tv
if youre computer is hd ready,conect youar acustic research to youar computer, then youar computer to youar tv via a hd lead
Dec 27, 2011 | Acoustic Research Audio Players &...
Have a delcotron alternator ,what to know where no.1 terminal and no.2terminal wire goes it is on my 1946 cj2a jeep my amp hand does not show a charge had alternator checked out and is ok
  • Use a wrench to remove the negative and positive battery cables: They are clearly labeled "+" and "-." Always remove the negative cable first, as this isolates the power to the metal parts of your car. Tuck the cables away from the battery as you don't want them to accidentally touch a battery terminal when you're wiring your alternator.
  • 3
    Locate the alternator terminals. There are two: one marked "live," "pos" or "+" and the other marked "neg," "field" or "-."
  • 4
    Locate the two cables. The positive (red) cable goes to your battery via a wire loom or harness. The negative (black) cable attaches to a metal part of your car.
  • 5
    Check how the cables attach to the alternator terminals. Some connect using eyelets that hook over the terminal and tighten with a bolt; others connect by inserting the wire under the terminal and tightening a bolt.
  • 6
    Loosen the two bolts using a suitable-sized wrench or, if the cables connect using eyelets, remove the bolts.
  • 7
    Insert the exposed end of the negative (black) cable under the loosened bolt on the negative terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 8
    Insert the exposed end of the positive (red) cable under the loosened bolt on the positive terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 9
    Replace the positive battery cable on the positive battery terminal using a wrench. Replace the negative battery cable on the negative battery terminal.
  • May 17, 2011 | Jeep CJ Cars & Trucks
    I have a 2001 cavalier with a dim driver side headlight. Have changed the bulb, DRL relay and headlight switch. Removed the ground cable from the battery tray, cleaned ground cable and battery tray contact...
    Give this a try------get a piece of wire and strip both ends, the black wire coming out of the plug on the head light, stick one end of the wire in there and the other end to a good ground or the negative battery terminal with the lights on, if the light gets brighter, there is a bad ground to that light. I hope this helps, cause you have just done about everything else.
    May 15, 2010 | 2001 Chevrolet Cavalier
    Can the starter button on a 1983 gold wing be cleaned?mine hesitates before turning over.
    first before breaking tis switch take a close loock at the battery cable end remove and clean them also check the ground wire from the battery at its other end and the positive at its end. most of these switchesn are not ment to be taken appart.
    Feb 16, 2010 | 1983 Honda GL 1100 Innerstate Gold Wing
    Snapped off at jack leaveing three exposed wires
    Yes.Here is some info:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
    Oct 24, 2009 | Audio Players & Recorders
    Dryer does not start
    I just fixed my 110.73932102 model dryer, and have done about a week of web research on that problem. I got a electronic control board from AppliancePartsSolutions.com for about $60 delivered-took about 4 days. Use flat screwdriver to pop off plastic ends of top console. Under plastic ends, find one screw (phillips) on each end-remove. Then, slide console forward 1/2 inch and it should open back to expose innards. Note-follow static elec. charge abatement procedures around all electronics! Part snaps out and in after disconnecting wiring. 20 minutes, tops and you're running again. Less than the service call! Good luck.
    May 09, 2009 | Dryers
    21 people viewed this question
     Grubhead
    Grubhead
