Question about Lexmark Office Equipment & Supplies
What number black ink cartridge do I use for Lexmark X4270 do I use
  • 105 Answers
Hi. welcome to fixya.
black cartridges are either.... 70..71..75
color are.... 19..20..25
you can find this in your solutions center/maintain troubleshooting/maintenance section. or in your user manual. if you don't have a manual you can download one here... http://safemanuals.com/user-guide-instructions-owner-manual/LEXMARK/X4270-_E
Posted on Sep 27, 2008
  • 11 Answers
SOURCE: no color printing with lexmark x4270
Actually your printhead on the cartridges is probably clogged. I usually take the cartridges out, wet a paper towel and put in a dish and put in microwave for 20 seconds, then put the cartridge printhead on the paper towel for 10 seconds, and then blot with a dry towel. You should see the various colors in the color and black cartridges. Do it several times until ink in freely flowing. Put back in printer and run a clean cycle and try printing normaly. For additional help: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS18888&relevance=1
Posted on Mar 07, 2007
  • 684 Answers
SOURCE: printer not printing
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now try to Print i am sure it should work.......... Good Luck............
Posted on Jan 19, 2009
  • 82 Answers
SOURCE: black ink cartridge in lexmark fax 4270
can you clarify? This is a fairly straightforward replacement.....Lift up the face of the machine, wait for the carriage to come over and fully stop moving, remove old cartridge and replace with new.....maybe more info on what is actually happening or not.....
Posted on Mar 10, 2009
Roop1980
  • 228 Answers
SOURCE: Color Cartridge Missing
Please follow the steps given below:
1 Turn the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Remove the print cartridges.
4 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5 Repeat Step 4 for the other cartridge slot (if applicable).
6 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7 Plug the printer/All-In-One back into the power outlet and turn it back on.
Next, try to perform a Self test:
1 Press the Copy button on the operator panel once (this button is located under Mode).
2 Press the Options button ten times until Maintenance appears on the display.
3 Press the left arrow button (-) once. The display should now read Self Test Page.
4 Press Select. The printer will print a hardware test page.
Posted on Apr 05, 2009
Samyfam
  • 379 Answers
SOURCE: I have a all in one printer from Lexmark X4270. I
Unfortunately I suspect there is a major fault that isn't worth repairing.
My father had a X1270 which developed a similar fault which could not be cured with cleaning or replacement cartridges. Dismantling it revealed no physical problems with connectors or cables, so it had to be the electronics.
Cost of a repair by a Lexmark agent would be far more than a new printer ! Printer only 15 months old when fault appeared.
My father has now moved and his new neighbour has just thrown his Lexmark in the bin - also less than two years old.
Personally would not touch a Lexmark again.
Posted on Aug 11, 2009
Lexmark X4270 gives an error message...black cartridge missing. It is not missing. what is the problem
Make sure you are using genuine Lexmark black cartridge. Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try to reinsert your black cartridge and make sure it is properly seated in the cartridge carrier. If error comes back up right after placing it in the printer, then it could be a faulty cartridge. Try to replace it with a new genuine Lexmark cartridge. If you are already using a genuine Lexmark cartridge, please contact Lexmark Technical Support Center for additional assistance.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do you know and find the cartridge number in a x 4270 lexmark printer?
The Lexmark X4270 printer uses cartridge number 70, 71 and 75 for the Mono Ink Cartridge. For the Color Ink Cartridge it uses 19,20 and 25. You can check this link - http://bit.ly/d2bbwm if you want to purchase these cartridges. Thanks.
Aug 15, 2010 | Lexmark X4270 All-in-One Multifunction...
I need to know how to get to the ink cartridges on
  1. Make sure the All-In-One is on.
  2. Pull the control panel toward you, and then open the cartridge access door
The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy.
  1. Pull the old cartridges toward you, and then lift them out. Store them in an air tight container or dispose of them.
If you are installing new cartridges, remove the sticker and transparent tape from the bottom of the cartridges.
Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
Push back firmly on the cartridges until they snap securely into place.
Close the cartridge access door, and then close the control panel.
  1. Use the buttons on the control panel to answer the questions that appear on the display:
  2. If the color cartridge you installed is new (it has never been used), press Select.
If it is old (it has been used), press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the color cartridge you are using, press Select.
If it is not the number of the color cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. If the black cartridge you installed is new, press Select.
If it is old, press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the black cartridge you are using, press Select.
If it is not the number of the black cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. Continue with Aligning the print cartridges to ensure proper installation.
Note: You can also use the Lexmark Solution Center to install the print cartridges
  • Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution Center.
  • From the All-In-One Center, click the Maintain/Troubleshoot tab, and then click on a topic.
    Here is the manual
    Hope that helps you :)
Nov 17, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark X4270 fax machine, and I have just got a new black ink cartridge. The old one was a lexmark 71 the man at Quill said to get a lexmark 75 hi-yield. so I did my machine keeps saying black...
Did Quill sell you a "OEM" (Original Manufacturer's Equipment) or a cartridge a third party cartridge?
If it is a third party ink or cartridge, then that's your problem. Lexmark does not condone the use of third party ink or cartridges. This is considered to be product tampering by Lexmark and they will void the printer warranty if damage results from the use of these type cartridges.
I do apologize for the bad news, but I do ask that you do not shoot the messenger. :-)
Jul 03, 2009 | Lexmark X4270 Printer
Black ink cartridge in lexmark fax 4270
Mar 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmarkx4270 all-in one
Remove the black ink cartridge and examine the print head on it - you will probably find a small piece of tape (very thin) covering the jets - usually blue in color - remove it and reinstall the cartridge.
Nov 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Sep 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Black ink cartridge - won't print
It is not unusual to receive a bad cartridge. The ink or the fiber in those cartridges are subject to blocking ( drying) while not in use.
That would be the most likely problem.
Apr 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
