Question about Gateway 830GM PC Desktop
3 twisted power led wires coming from the power button
I need to know how to hook them up to the motherboard please. This is driving me crazy.
  • pndycedo Sep 27, 2008
    Thanks, I hooked it up according to your diagram, still the computer will not come on though. Thanks.
  • Gateway Master
  • 13,433 Answers
Thats how, also see if the wires got any text on them , if they don't you will need to figure out what goes where and then connect accordingly to the picture.
Posted on Sep 27, 2008
  • Ekse Sep 27, 2008
    disconnect the power switch connector from the motherboard, use a screwdriver to connect these two pins together for 1-2 seconds then pull the screwdriver out, it will work as a power switch / button. If the computer starts up, the wires of the power button is broken.
  • Ekse Sep 27, 2008
    thats pin 6 and 8
Cant find my motherboard pin out
http://www.pcmag.com/article2/0,2817,2388344,00.asp?tab=Specs
With all due respect, you have the manual in front of you now
That is unless you started unplugging wires already, and didn't make notes, drawings, or take photos.
Let's use the Asus Essentio CM1630 motherboard for an example.
Couldn't find a CM1730, but that's OK. We'll use this one for a general example,
http://www.ebay.com/itm/OEM-ASUS-ESSENTIO-CM1630-MOTHERBOARD-61-MIBBJ5-01-TESTED-/181007679725?pt=Motherboards&hash=item2a24e600ed
Put your mouse cursor in the middle. Now move your mouse around, using the Zoom In feature.
If this motherboard were mounted in a computer case, it would be turned 90 degrees to the Right.
Bear that in mind.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Goes by many abbreviated names.
PNL 1, FP1, PANEL1, etc.
(Panel 1, Front Panel 1, Panel 1)
Go to the Top/Right corner of the motherboard photo. To the 6 Blue SATA connectors.
Immediately to the bottom of them, is a white Front Panel header.
Two rows of contact pins sticking up.
You need to make notes, drawings, photo, whatever; of where the wires from the Front Panel, go to each one of those pins.
(Some may not be used)
How to know which wires coming from the Front Panel, are the Power On switch wires, Power On LED light wires, HarDDrive activity LED light wires?
Remove the Front Panel from the computer. If it is Not just a cover, EASE it off just enough to look behind it.
You usually can follow the Harddrive activity LED wires.
Harddrive activity LED is usually AWAY from the Power On switch, and Power On LED light.
There's two wires down.
Now look at where the Power On LED light is. Can you see wires going straight to it?
Two more wires down.
From process of elimination, you now know the last two wires going to the Front Panel, are for the Power On switch.
(The Power On switch, is part of the plastic Power On Button assembly. If you look close at the Power On Button assembly, you can see this)
THAT sir, is the MAIN thing.
I can guide you where the other cables go, as far as power cables, and Harddrive cables, and Optical Drive cables. (CD/DVD drive)
If you have already disconnected the Front Panel wires to Front Panel header on motherboard; you get to play a game(?)
Power Supply plugged into power, use a small flat tipped screwdriver, and touch two pins at a time.
When you get to the two Power On switch wire pins, the Power Supply will come on.
Now it is a process of elimination.
Use an LED with two wires, to find out what the rest of the pins are.
The rest of the contact pins in the Front Panel header.
Grab the HDD LED light, or Power On LED light.
You're getting a new computer case anyway.
Touch two pins, and the LED light blinks?
That's the HarDDrive activity LED light, pins.
LED stays on?
That's the Power On LED light, pins.
Either of those LED's are dim, (When the Harddrive is active, or when the computer is on), switch the wires around.
You have the Positive ( + ) wire mixed up with the Ground ( - ) wire.
Moving on.............
The 6 Blue SATA connectors on the motherboard:
If you look close you will see;
SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5.
Or it may be,
SATA1, SATA2, SATA3, SATA4, SATA5, and SATA6.
The Harddrive plugs into SATA0 or SATA1.
Just depends on what the SATA connector numbering starts with.
The main optical drive, or a single optical drive; plugs into SATA1, or SATA2.
A secondary SATA optical drive will plug into SATA2 or SATA3.
(Look at the SATA numbering above, and you can compare side, by side )
HOWEVER, the beauty of SATA is; that you can plug whatever you want to, in ANY SATA connector on the motherboard; and BIOS will find it.
Plug the Harddrive into SATA 3? No problem.
Plug the optical drive into SATA 0? No problem.
BIOS will find the drive with the Operating System on it.
The Harddrive.
Then BIOS will know the other drive/s are optical drives.
(Make sure in the BIOS Setup utility, that the SATA connector on the motherboard you are using, is Enabled.
Otherwise BIOS will Not see the drive)
What cable from the Harddrive, and optical drive; plugs into those SATA connectors on the motherboard?
A SATA data cable,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable connector.
Lines up with an L-shape on the motherboard connector.
One example of a SATA connector on the motherboard is shown.
This one is an Open design. Your SATA connectors on the motherboard, will be a Closed design.
Between a SATA data cable connector, and a SATA power cable connector, the SATA power cable connector is larger in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
See the SATA harddrive example?
Note the L-shape is pointing DOWN. It is this way EVERY time.
Now you know which way to turn the SATA data cable's connector, when installing. 'Foot' of L-shape goes Down.
More in a Comment.
Mar 14, 2013 | Computers & Internet
E-Machines T3508 PC Desktop Motherboard connecting the wires
The eMachines T3058 Desktop PC uses an Intel D101GGC motherboard.
The plastic front of your computer is the Front Panel.
The rectangular area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Front Panel header:
This link takes you to Intel Support, and the download page for the motherboard manual, for the Intel D101GGC motherboard,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
On this page click on the blue -
Intel Desktop Board D101GGC Product Guide - English (PDF)
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
{ Took 7 seconds to download just now, with no additional download time needed.
Using medium speed DSL connection }
Ignore the following if you are aware;
At the top of the PDF file is the PDF file page number box, and the Zoom Out/Zoom In icons.
Zoom Out ( + ) enlarges the page view, Zoom In ( - ) reduces the page view.
For myself I reduce the view size to 100 or 75 percent.
The page number box is to the right of the Down Arrow.
(If you do not see this, hover your mouse cursor towards the bottom/middle. When the icons come up, {They were 'ghosted out'}, click on the PDF icon to the far right )
Provided that somehow you cannot download this motherboard manual;
Orient the motherboard so we are both looking at it in the same direction.
Same as it sits in the computer case.
Processor to the Top, Ram Memory to the Right, white PCI slots to the bottom.
The Front Panel header is at the Bottom/Right.
It is a rectangular block of plastic with two rows of pins.
4 across the Top, 5 across the Bottom.
It is numbered Even on the top, and Odd on the bottom.
Starting at the LEFT side going towards the right, on the top row;
Pins 2, 4, 6, and 8.
There is no Pin 10, just an empty space.
Starting at the LEFT side going towards the right, on the bottom row;
Pins 1, 3, 5, 7, and 9
A) Pins 1 and 3 are for the HarDDrive activity LED light. (Orange)
Pin 1 is for the Positive wire ( + )
If the LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Blue)
C) Pin 9 is for 5 Volts. Not Used (Black)
D) Pins 2 and 4 are for the Power On LED light. (Green)
Pin 2 is for the Positive wire ( + )
If the LED light is dim switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Red)
Do not know what wires coming from the Front Panel are the Power On switch wires, Power On LED light wires, or Harddrive activity LED light wires?
Remove the Front Panel, trace the wires to the Power On switch. (Two wires. Probably twisted together. Or all wires are in a single sheath)
Same for the Power On LED light, and the Harddrive LED light.
Need to know where the harddrive, or optical drive plugs in?
Need to know where the power cables from the Power Supply plug in?
Please post back in a Comment.
Regards,
joecoolvette
Oct 11, 2011 | E-Machines T2893 PC Desktop
Power switch hook up on e machine t3624 front panel as 3 hook up each has 2 wires with letter labels wire hook up r label HDD LED wires red white / labelPWR SW black white / label PWR LED wires blue...
This is not a photo of your motherboard. Please use it as a general guide on what to look for on your motherboard. Most brand name systems will have the connector pins placef on the edge of the motherboard that is closest to where the wires coming from the power button are being routed. Pay attention to a set of pins that equal the amount of connection wires you have. When you see it, look around the pins and you will see etchings that describe which wire goes on what pin.
NOTE: Please remove the AC cord from the computer and that all keyboard, mouse, video, network cable and usb slots are disconnected and empty. Do not power the pc until you are certain you have matched the connectors to the right pins.
Jun 01, 2011 | E-Machines T3624 PC Desktop
I have purchased a Thermaltake V3 black case and am trying to install my M2N68-LA motherboard. The motherboard has a combined 9 pin header for power switch, power l.e.d. and hdd l.e.d. which was one plug...
1) The 9-pin header you are referring to, is the Front Panel header.
(Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner on the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00906129&lc=en&cc=de&dlc=&product=3397528
The plastic piece on the front of your computer is the Front Panel.
(Sometimes referred to as a Bezel)
Make a drawing, and notes as to where the individual wires go from that Front Panel header plug, (One-piece plug), to the Front Panel.
Follow the wires from the plug to the Front Panel.
Mark down where Each wire goes.
You may have to take components off of the Front Panel, in order to see exactly where Each wire goes.
For example:
You may have to remove the Power On button/switch assembly from the Front Panel.
It may have the Power On LED light, Power On button, (Switch), and perhaps the HarDDrive LED activity light, in this assembly.
The wires are color coded.
Generally, but not always, when two wires are used in conjunction with each other, (Example, Power On switch, or Power On LED light), the wires will be twisted together.
One wires insulation may be of a solid color, and the other wire may be white, with a stripe in the color of the solid wire.
Example: Wire with Red color, and wire twisted with it may be White, with a Red stripe.
See if these two wires go to the Power On switch.
End of example.
Follow each twisted pair of wires back down to the Front Panel header plug.
(One-piece plug)
See which socket holes the individual wires go to.
Mark it down in your drawing, and notes.
Mark where the individual socket holes plug onto each pin, in that Front Panel header. (9-pin header)
When you are finished, you will have a pinout for the Front Panel header on the Asus M2N68-LA motherboard, and will know where the individual wires go from your ThermalTake V3 computer case.
For the LED lights there is a Positive pin, ( + ), and a Ground pin. (Power On LED, and Harddrive activity LED, for example)
(Ground. Also referred to as the Negative pin. ( - )
This is DC Voltage)
If you have the polarity backwards, (Positive wire of the LED light is going to the Ground pin, Ground wire of the LED light is going to the Positive pin), the LED light will be dim.
(When operating)
Switch the wires around.
If you have questions, or need clarification of what I have stated above, simply state in a Comment.
(Believe upper right of your page)
Jul 01, 2010 | ASUS Computers & Internet
I need to know how and where to hook up the power buttons on the Chaintech 7VJL (VIA KT333) motherboard along with led light. I have forgotten where the little wires plug into??
Well there is a steker on the Casing ususally which tell where to plug in the led and power cord on motherboard.. if you have not lost it..
Jun 24, 2009 | Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
I hook everything up and turn it on but i get nothing
if you just built a new pc, and hooked up your power button and reset button and mixed up the possitive and negitive wires you may have fried your motherboard. If you hold the power button for five seconds and your pc does not power down, it's fried.
Apr 11, 2009 | ASUS P5WD2-E PREMIUM GREEN INTEL 975X...
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Gateway 830GM PC Desktop Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
