Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WS 65909 Power
TV worked great then I moved it to another room.Plugged it in now all I get is the timer light flashes and doesn't stop.NO picture?
  • 3 more comments
  • bsimko1647 Jan 12, 2009
    I actually tried to plug in a U Dance for my daughter and now when I turn on the TV the green light comes on and about 10-20 seconds the tv shuts off.
  • gil oetting Jan 17, 2009
    I also moved my WS65909 and get a blinking green light that won't stop, push reset and starts up again.
  • cafk92 Jan 18, 2009
    I have constant green led blinking. Tried al the reset tricks. I followed instructions, only my DM board had 7 caps rather than 4 that looked fine . I replaced them all, and it did not work. Now I want to test the voltages at KA pins,
    but where is the KA connector?
    Just an FYI Mine is a 65909, and none of the pictures matched exactly that I have seen so far.
  • artahbaz Mar 22, 2009
    I unpluged the tv and moved it to another room and when i pluged it again all i get is the timer blinking and no picture.
  • donald612 Apr 26, 2009
    I have a WS65909 that was recently returned to me from a local repair shop unable to be fixed. I am told it is the DM board and that is is not available as replacement or repairable. Any suggestions?
  • 2,071 Answers
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Mitsubishi WS 65909 Power - a3d2d2a.jpg You must do some checks first:LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001.
Just click below for more information.; http://www.fixya.com/support/t838883-mitsubishi_wd_52825_tv_wont
Hope it may help you ;
Regards,
VOTIT
Posted on Oct 08, 2008
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
The timer light is flashing
the timer light is flashing continuously. reset does not work
Mar 09, 2010 | Mitsubishi WS-65909 65" Rear Projection...
55" mitsubishi timer light flashes
I just had the same problem have you figured out how to fix the problem?
Nov 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a mitsubishi ws-65909 - flashing 2,2. Can
I have this information but it is too large to post here.
Let me know by rating this solution and I will find a way to give you the instructions.
SD TECH
Nov 13, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Timer light binking green
U have a DM problem CAPs burned out. download repair manual for your TV.
Jun 30, 2009 | Mitsubishi WS-65909 65" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mistubishi ws-65909 will not come on
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Dec 01, 2007 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
5,385 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
