Question about Emerson NR303TT CD Shelf System
CD player does not work
The system was bought about 2 weeks ago and the CD failed to work out of the sealed box. This is not an as-is or display system.
The CD drive does not display the available tracks on a CD and does not play the CD.
I made this one-time observation.
While a CD was in the drive, I checked out the other devices -- Radio, Tape Drive, Turntable. While switching back and forth between devices, I noticed that at one point that the dispay showed the CD track numbers. I then got the CD to play. Also, CD FF, FR, Pause/Play selections worked. Elation!!!!After playing several tracks I stopped the CD to start from scratch; remove and insert the CD but it never worked again. I tried different CDs, jiggled the selector knob, waited minutes for the track display -- no deal.
P.S.
I hope you can guide me to a fix. I am handy with tools.
Emerson advised me to get another system from the merchant. But the merchant (Boscov's) is closing the store and all sales are final -- no exchanges, no returns. I have no problem with that policy, but I should be entitled to a working product. My alternative is to send the system to Emerson but I am not (yet) ready to spend approx. $50.- round trip UPS fees.
10/6/08 Update.
Solved the problem myself.
Repositioned the printed circuit board with the CD Drawer open/close limit switch.
I suspect that the board shifted during shipping and failed to trigger the closed drawer position.
Player is now working.
Posted on Oct 06, 2008
Good day,2.2 2014 5 spd box twice in one week my i light circle came one and then no turbo??101164 km on bought vecichle a month ago and blown gearbox two weeks ago any help
what maker of vehicle
ecu will have fault codes to be read
loss of power on a turbo can mean many things
very complex systems
turbos and gearboxes do fail.....thats a fact
Mar 26, 2017 | Cars & Trucks
Master cylinder replaced 2 weeks ago all ok then brakes failed so bled system still failing no leeks no air in system
Master Cylinder has internal bypass leak, the leak isn't visible. The seals inside the master cylinder have failed.
Aug 24, 2013 | Kia Cars & Trucks
BOSE WAVE MUSIC SYSTEM PLAYS CD BUT DOES NOT TURN OFF
It is probable that the battery will need to be changed, this the first step to find out if additional work is required.
May 17, 2012 | Bose Wave music system with multi-CD...
A/c WOULD NOT WORK. TOOK TO A GARAGE AND THEY TOLD ME RELAY WAS BAD AND CHANGED IT OUT. aFTER THEY SAID IT WAS "FIXED", drove away and noticed radio did not work at all, no time display or...
Sounds like a case of selling a car, when the problems
become too stressfull & you bought it
Your shop tried but may not have been
in the upper 10% skill wise
Need the best place around & a
fresh start.
I think they had the battery disconnected
& ran out of knowledge when it can time to
give you the car back.
I won't even guess without the car to test
May 26, 2011 | Chrysler Concorde Cars & Trucks
My cd player was bought 2 weeks ago. so far I have used 2 double A batteries every other day. why? Is this normal? please help. thanks Idea
There is an electric motor in your CD player and this uses most of the battery power. Time of use is related to quality of batteries Duracell being the best usually and how long you are running the CD player. Why not get a cheap mains adaptor for indoor use and save your batteries. You could try good quality re-chargeable batteries, they usually work but some players are picky. Good Luck.
Feb 14, 2011 | GPX Audio Players & Recorders
I get the TOC Error, when I put bought cds in.
don't think you will like this answer but, it probably time to get a new cd player... you could try using a cd cleaner designed to clean the laser or spray the insides with compressed air.
Apr 29, 2010 | Kenwood KDC-MP228 CD Player
Car CD player plays but has no sound
Does your car have a premium sound system? Assuming that your cd deck is fine, try connecting your remote turn on wire from the sony to the corresponding wire on the car(if you bought a wiring harness, just match colors). Also some chryslers used a ground to turn on the amps.. a black wire with a female connector as well as a heavy ground ribbon cable... connect those 2 AND the ground to your stereo to enable the amplifiers.
Jun 23, 2009 | Sony Car Audio & Video
Zeros on the display
where you bought it should have a record of you buying it as well, make sure to bring all thr proof who you are, and try to remember the date you bought it. all the info you can give will help them locate the sales tag.
Sep 30, 2008 | JVC KD-PDR30 CD Player
CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Jan 06, 2008 | Kenwood DPX-501 CD Player
Emerson NR303TT CD Shelf System Logo
241 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
