Question about XRS 9540 Radar Detector
Burned Cobra 9540
My Cobra 9540 detector stopped working and unfortunately it was purely my fault. I bought a hard-wire kit, wired it up, and it worked fine. Well one day I changed the location of the detector, thus moving the wire. When I plugged it back in and turned it on, I discovered that I reversed the polarity of the plug (It was a universal hard-wire kit with changeable plugs). It smoked, I was pissed. Oops. Any chance it's fixable?
Smoke detector looks burned
Air may flow through the unit if you don't have a vapour barrier wrapped around the electrical box in a ceiling with an attic above. The smoke detector may look smoky and it may have come from cooking grease in the air. This may foul the smoke detector. All smoke detectors have a piece of radioactive americium-241 that creates ions in an ionic chamber. This chamber has to be pristine. That is why smoke detectors have a replacement date on them. It may be time to get another one. Some kits come with a cardboard baffle to stop so much air sucking through the unit.
Nov 07, 2013 | Kidde 1275 Hardwire Smoke Alarm with Hush...
I hard wired the xrs radar but didnt install the fuse, got it shorted out and now it wont turn there a fix to replaced whatever i burned up?
check for power on the line you may have popped that fuse if fuse ok than you more than likely burnt up most of the electronics in your detector
Aug 22, 2013 | 14 Band Radar/laser Detector Xrs 9345 With...
Can you show me where to get the user manual for a cobra superwide laser detector with model number r-213
Unfortunately, Cobra does not provide secondary or tertiary manuals on their website for this old model of Laser Detector.
Your best bet would be to either purchase a new Laser/Radar detector from Cobra and get the manual from that.
Hope this helps.
Jun 03, 2011 | R-213 Radar Detector
My speaker stop working
Check the sound drivers in your system and also check whether the speakers have been properly plugged into the system
Thank U
Please rate me as it wil cost u just one click
Oct 23, 2009 | XRS 797 Radar Detector
Need a manual for cobra xrs 797
send an email to or you can call 773-889-3087 for their cust serv m-f 8-530pm cst. their website has other newer manuals for pdf download but unfortunately yours is unavailable
Aug 07, 2009 | XRS 797 Radar Detector
Cobra radar detector xrs-989 manual then support then downloads then radar detectors.
Problem at the moment is Cobra is working on their server and the pdf is unaccessible right now, however, this is the link. Hope this helps
Jun 19, 2009 | Cobra Vehicle Parts & Accessories
I dont understand
That may be because he does not have his radar unit activated. Radar units work by sending out a microwave signal. It bounces off your car and back to the unit. It then calculates the whole distance over time thing and figures out your's more complicated than that, but I don't feel like giving a class...and I'm not a real genius anyway when it comes to physics and whatever other -ics are involved with the science of radar. Point is...radar units have a hold function..kinda like turning that microwave beam on and off...when the officer has the radar on "hold" there is no beam coming out..which means, there is nothing for your radar detector to detect. When he takes it off hold to clock your speed, the magic beam shoots out, bounces off your car, and returns to the unit..then tells the officer your the time your radar detector actually lets you know you're being clocked, Mr. Officer is already turning around to come pull you over. Hence the reason radar detectors are a waste of money...but then again, there are plenty of cops that ride around with the the sending out a signal all day and never actually put it on hold...if a cop is using the radar properly, the radar detector in your car will not help you...but, not everyone does what they are supposed to do, so therefore, it may save you from one or two tickets.
Now, the reason it doesn't alert you when the police are right in front of you is because either the police in front of you; A)do not have a radar, B)do not have their radar on, C)they have it on "hold" and are not transmitting a signal, or D)your radar detector is broken and you need to get it fixed or replaced.
Jan 11, 2009 | XRS 9540 Radar Detector
Cobra XRS 9430 Sound Stopped Working
ok, stupid question but is the volume turned up?
Nov 10, 2008 | XRS 9330 Radar Detector
XRS 9540 Radar Detector Logo
50 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
