Question about Garden
6 yr old mower starts, won't run
Yard machine by MTD, i've replaced plug, filter, gas line...after priming 3x, it will start and run briefly and then won't start again until i wait a few minutes and prime again?
  • 48 Answers
Sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
Posted on Oct 21, 2008
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
My 5 hp MTD mower keeps stalling after running for a couple minutes. I then prime it excessively and it will start back up and do the same again. I have cleaned the carb and replaced the priming needle,...
You probably have already done this, but I had a JD 111 rider awhile ago and did most of the things you have done with no success. Then I replaced the fuel line and "BINGO" it worked great after that. Seems the line had a weak spot and would **** closed when trying to start.
Good Luck
Jul 10, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Jun 05, 2011 | Mtd 22" Yard Machine Push Mower
My mower will only stay running if I keep priming it. Bought it new this summer and only used it 5 times at 20 min.. I have replaced the gas. Same even if the filter is off so its not the filter.
You probably got gunk in the carb?
Dirty gas, bad can, old, etc, etc
Clean the tank really good, remove & replace the fuel filter, add new gas - After.... you clean out the Carb. Maybe even rebuild with an inexpensive kit you can get on eBay or Amazon.
Good Luck
Get part number from here:
Lawn Mower Parts Genuine MTD Parts for Outdoor Power Equipment
Sep 19, 2010 | Mtd 22" Yard Machine Push Mower
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
Lawn mower won't start
Did you set the plug gap to specs?
Check fuel line filter.
Empty gas a replace with fresh fuel.
Apr 06, 2010 | Mtd 22" Yard Machine Push Mower
Won't start. Mower was in storage and unused for 2 yrs. Replaced spark plug. Still won't start.
IF you are turning it over and getting spark then your not getting fuel
2 year old gas can turn to sludge plugging the filter in the gas tank clean the tank out - blow the fuel line from the carb. back to the tank- use fresh gas she should run
Mar 11, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
779 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
