Question about Vacuums
Just bought a Hoover steam vac. Did the dining room. everything okay.. emptied recovery tank and replaced. started on living room. dirty water not going into recovery tank. carpets very wet. What did I do wrong and how do I correct it
  • 37 Answers
You may have put the lid on your recovery tank on wrong. on some models you have to lock the front in first then snap it down in the back. if you can pull the lid away from the tank then its on wrong and isnt making a seal.
Posted on Sep 28, 2008
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
Empty dirty water tank, replaced it and then started to clean again. It did not **** up the water.
The only reason for no pick up is an air leak. The most likely problem is that the lid is not properly seated on the dirty water tank. A less common problem is that the round rubber seal the tank sits on is out of place.
Jan 28, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have the hoover steam vac f5906900 and im just trying to use the detachment. I plugged in the water part but i cant get any suction. the water is spraying out that is all....help my dog **** on my bed...
Hi, The attachment hose also has to be plugged into the dirty water recovery tank. The other end of the hose which has the square plug, must go in the spot on the recovery tank where the water comes up from the floor. To do this, Remove the lid of the recovery tank, slide out the little rectangle (usually same color as the recovery tank) which is located just above the clear water channel from the floor there, and insert the square piece for the attachment hose. It should only fit in one way. Replace the lid to the tank and you should be ready to attack the ****. Good luck. Mark
Nov 10, 2010 | Hoover F5906-900 Upright Steam Vacuum
My steam vac stopped sucking the water up
make sure the lid on the dirty water container is on tight and the tank itself is locked into place, also check to make sure the clear window in the front of the machine is tightened down firmly
Oct 20, 2009 | Hoover F5858-910 SteamVac Vacuum
Steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
73 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
