Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Left Door open now it wont power up
I left the door open on my Subzero 650. When i returned, all of the poer to the fridge was off
How do I reset it to start up again
Thanks
  • 958 Answers
You can un plug it for 30 minutes to an hour and plug it back.
hope it would run normally.
tnx 4 using fixya,
drcool
Posted on Sep 27, 2008
Subzero fridge door left open. Has a new compressor just recently. Is there a reset button on the compressor to get it going again
The compressor has probably overheated. Leave the fridge unplugged for a few hours until it cools down. If you keep trying to use it, the compressor will fail again. They have a self resetting thermal cutout but these will fail if the compressor keeps overheating.
Sep 17, 2017 | Refrigerators
I left the bottom freezer of my 650 ajar and when I returned the unit was producing a loud buzz - presumably a motor or fan. It turns off if I pull the shelf that contains the ice tray forward.
When the door is left open alot of condensation forms in your fridge which freezes and ices up. This build-up will gather around your evaporator fan which sometimes stops it from working or sometimes the fan blades scrape on the ice built up.
Best to manually defrost your freezer. Empty your freezer. Turn fridge off. Put a pot of boiling water and close the door. Leave for some time to defrost the ice. You can repeat this a couple of times to defrost the ice. Otherwise you can use a blow-dryer as well.
When you defrost, and turn your fridge back on. Everything should go back to normal.
Ash
Sep 18, 2011 | Sub-Zero 650 / O Bottom Freezer...
Subzero refrigerator is not cold. freezer is fin
you could have a leak in the sealed system,most likely the evap coil.in the fridge section,is there any ice on the left side back wall?look at the back wall on the left side around 12 inches up from the bottom draws,if there's ice there you have a freeon leak and you'll need it replaced.look at your warranty,i believe the sealed system is under warrany for the first 12 years and it's around 650 dollars to do the job.there are two compressors,one for the freezer and one for the fridge.also open the door,you'll see tow switches on top,push them in,does the lights go out and the fan come on,i've seen the light switches stick,the lights stay on and the fridge gets very warm.how old is it?if it's digital is it saying to clean the coil or anything like this?
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Door left partially open, cracked. unit is off and will not come back on. how to restart?
I read about this somewhere. Leaving the door cracked open caused the ice box to get an air blockage. I think the solution was simply to unplug the unit and let it thaw out. Tried to find the thread in my forum with no luck. Sorry. From past experience, It is dang near impossible to get any information on SubZero online.
Nov 25, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero stopped working after door left open
whe n you left the door open the fridge have a sensor. and turn the LIGHTS OFF. close the fridge let it cool again.
Aug 09, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Subzero door left open and now motor won't start
yeap. wait to cold back. the fridge have a sensor to shut the lights off. the reason; LIGHTS REALLY POWERFULL. CAN BURN THE LIGHT COVER
Jul 15, 2009 | Sub-Zero 601R
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650 not running
Check the light switch on the door frame, if that doesn't do the trick change the light bulb. If your refrigerator is not running and cooling and the light is out check the power, plug & circuit breaker in the power center.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Subzero door left open - now acting strange
You have probably already figured this out, but if the door is left open there is a sensor that will turn the lights off to keep the fridge from overheating. After you close the door and let it sit with the lights off for 15 minutes or so, the sensor will cool and allow the lights back on. If the temperature reading in the window is ok and does not say "service" or "vacuum condenser", then you should have no more trouble.
May 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
699 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal De GO PATS
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
