Question about GE DBSR453EBWW Electric Dryer
No heat dpxr483" GE dryer run good but does not heat
  • danabparr Dec 28, 2008
    dyer has heat for 2 minutes than looses heat
  • 62 Answers
Need to ck the heating element, to see if any breaks in wire coil.
Posted on Oct 22, 2008
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Replaced coils / looks good and produced heat but now no heat
caused a short maybe ,reset circuit breaker and check 4 wire against frame
Aug 23, 2009 | GE Dryers
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
May 22, 2009 | LG DLE7177 Dryer
GE Dryer timer stoped working and so it runs and runs
Dryer knob assembly unit is faulty and loss of heat sounds like an element going out.
Dec 10, 2008 | GE DBSR453EBWW Electric Dryer
No heat on my GE prodigy dryer dpxr483
Here you get exploded view, so that you can locate the thermostat. There are two thermostats at the back of the drum, they are numbered 505 and 507 in diagram.
Here is the diagram
To access the thermostats, remove the back panel (see diagram), and undo the belt routing.
Sep 29, 2008 | GE DCSR483EA Electric Dryer
GE Dryer Mod DDE8040l heater coils
Check your voltage to the dryer, make sure you have the required 220 volts. If you are only getting 110 volts the dryer would run but not heat. So check the breaker or fuse box first,, then check the plug for proper voltage, then the terminal block to make sure you do not have a wired burned off.. after that it would most likely a high limit thermostat. Good luck. I hope this will fixYa. and dont forget to rate me. Thanks
Mike
Sep 06, 2008 | GE DBSR453EBWW Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
87 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
