Question about Garden
Chainsaw manual Do you have any ideas on how I can get an owner's manual for this gasoline chainsaw? Thanks, Dave
  • 2 more comments
  • artcur Nov 21, 2008
    I have a Homelite  XL 130 Chain saw.  What make and number of sparl plug should I use?
  • Anonymous Feb 17, 2009
    I need a manual for a homelite chainsaw 14 inch
  • tj_bb Feb 25, 2009
    the two little adjusting screws that are located above the primer bubble, are red and blue and are marked ''L'' and ''H''. what are they? and there is a third one that is seprate, marked ''T'' what is that?
  • yadayada
    yadayada May 11, 2010
    Go to the Homelite site and you will find the manual there
Dont know were is the air cleaner
Posted on Sep 27, 2008
I need to know what the gas to oil ratio is for a Husqvarna 372xp chainsaw is
Hi gducci1949...
Use a 50 to 1 mixture...1 pint of oil to 6 gallons of gasoline
Please take time to rate me
Aug 22, 2011 | Husqvarna Garden
Respected Sir, I purchase a Husqvarna's chainsaw last week Model 236- 14". but I cant start it. I read manual carefully, every thing is OK. but Chainsaw can't start yet. So I request you,...
Checklist:
2-cycle oil mixed with FRESH gasoline
Spark plug wire pushed onto spark plug
Chain tight but you can still move it forward with your hand
Switch turned on
Pull the cord a few times, and then let it sit for a few minutes in case it's 'flooded' with fuel
If a new chain saw won't start, it probably has defective spark coil
Chain saws usually don't cause problems fresh out of the box, they stop working if people leave gasoline in the tank for a couple months each time.
Here's what I would do
Empty the tank of gas. Put fresh gas-n-oil into tank (not gas from an old can that was sitting there for a while)
Try starting again.
If no luck, then take it back and exchange for another.
Good luck sir.
Oct 15, 2010 | Husqvarna Garden
I need an owners manual for a Stihl MS180 Chain Saw
Hello Dave;
An OM for your saw can be found at this link:
http://www.stihlusa.com/stihl_ownersmanuals/MS170_180_Manual.pdf
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 11, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I just purchased a Stihl 041AV chainsaw and need to know what the gas to oil ratio is. Thanks.
The quick/easy answer: Use Stihl (or comparable) two-stroke engine oil at 40:1. A good name brand gas is less likely to gunk up your engine.
Background:
The old manual recommended Castrol SAE 40 mixed at 20:1 with regular gas.
All the modern Stihl chainsaw manuals recommend using 90+ octane unleaded gasoline mixed with Stihl two-stroke engine oil at a 50:1.
Since this is an older saw that runs at a lower RPM than modern saws, you probably don't want to run it quite as lean as 50:1. 40:1 is going to be about the right mix
If you want a printed manual for your chainsaw, you can request one here.
Chainsaw collectors corner has some other useful specs here.
If this answer was useful, please give it a vote! Thanks.
Jun 14, 2010 | Garden
McCulloch 120 Chainsaw Owners Manual
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join).
http://www.arboristsite.com/showthread.php?t=72322
Include your e-mail address in your request or it most likely will not be answered.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 20, 2010 | Standard Oregon Chainsaw Chain For...
Wear is the model number on makita Gasoline chainsaw i tin I think it's DCS6401-20
You can download both the Owner's Manual and Parts Breakdown for a DCS6401-PH here:
http://www.makita.ca/index2.php?event=tool&id=265&catid=40
The manual says the ID tag is in the rear handle below the trigger. HTH
Lou
Sep 21, 2009 | Makita Garden
Owners manual for homelite chainsaw
Have your UT# available.
http://odref.com/homelite/chainsaw/index.html
Mar 27, 2009 | Garden
Garden Logo
469 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
