Question about HP PSC 1350 All-In-One Thermal Printer
Paper Feed Roller do not grab paper, Grinding noise, E for error message appears.
  • Anonymous Oct 07, 2008
    constant paper jam- makes a grinding noise
  • HP Master
  • 4,338 Answers
Here is an in depth document on Paper and carriage jams on your HP printer. there is a paragraph on how to clean the rollers, which may fix your problem.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=&cc=us&lang=&rule=35051&product=306892&docname=buu03110
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 08, 2008
Keep getting out of paper error and paper wont feed makes loud grinding noise
A screw or something else is in the printer not allowing the gear to move freely.
Apr 22, 2015 | HP C6280 Photosmart All-in-One Printer...
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
Will not feed paper and makes a horrible grinding noise.
clear paper feed roller with cloth and water or alcohol, if necessary replace roller
Jan 28, 2011 | Epson ACULASER CX11NF All-In-One Printer
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Clicking noise with MFC-8640D another case
Usually it's because the paper is too tight in the feed tray. The paper length tab on the end away from the feed roller is too tight. If you cant rotate the gear on the paper tray and lift the paper, it's too tight for the machine to lift.
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
Paper not feeding
The Dell 3000cn & 3010CN both display this fault.
The root cause of the problem is the Rubber pads of the feed roller in the paper tray become warn and fail to grip the paper the paper feeds a few millimetres and then is let go by the worn roller, the paper path sensors pick this up and then a paper jam is notified.
The only remedy for this problem is to obtain a new feed roller for the paper tray mechanism. Unfortunately dell in the UK do not sell maintenance kits to the public, and therefor ehte only place I found them wa on Ebay in the USA.
The kit in quetsion is the vertical paper feed maintenance kit. it costs around $50 plus shipping.
The only other option is to have a Dell approved service agent replace the rollers for you.
If you hear a grinding or cruching noise when paper is fed, then one of the mini plastic guide rollers had detached itself from its position and wound up in the tape path mechanism (very expensive repair)
Jul 12, 2008 | Dell 3000cn Color Laser Printer
HP PSC 1510 printer malfunction
Open the rear cover and clean the roller with clean water. Worked for me.
Mar 05, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printer won't advance next piece of paper
You can get a repair kit for this off ebay.
Your paper feed roller and lifter are worn.
Jan 30, 2008 | HP LaserJet 1012 Printer
Paper won't feed
Pull out the paper tray and push the paper feed roller towards the machine. Try to turnaround the paper feed roller by hand. Reinsert the paper tray.
Nov 02, 2007 | Brother MFC 420CN All-In-One InkJet...
HP PSC 1350 All-In-One Thermal Printer Logo
379 people viewed this question
Ben Johnson
