Question about Hoover U6434-900 Bagged Upright Vacuum
Belt Keeps slipping off shaft
I replaced the main drive belt when it slipped over the end of the motor shaft, but problem still persists.  Is there a part that fits on the end of the shaft or is there a way to stop the belt from coming of the end of the motor shaft?
Thanks.  Mark markfjy@gmail.com
  • markfjy Oct 03, 2008
    I checked for looseness of pulley and trueness of shaft.  I agree, something must be causing this to skew.  Usually, the belt slips off when the power drive is engaged - that is to say the assist mechanism to help move the vacuum forward and backward.  So the brushes turn, the vacuum collects, but the forward and backward assistance mechanism is at the root of the problem.  So If you attach the belt, turn the vacuum on its side or upside down, the belt tracks true.  As soon as you engage the forward or backward assistance is when the belt usually slips off the shaft.  There is a lot of play on the lower vacuum head, if you will, and it does flex by design, but the entire unit flexes as a whole, not any of the individual parts, such as the drive wheels.  There must be some motion somewhere, I agree, that ever so slightly causes the motor shaft to untrue itself, but I have not found any play or looseness of individual components that would suggest that.
  • smiles9320 Nov 29, 2008
    I am having the same problem; the belt broke and I put on a new one. Now, the new one keeps slipping off. It come off right away and it just slides off the silver rod (excuse my ignorance). What can I do to fix it myself?
    President:
  • 1,673 Answers
If this is a new belt that keeps coming off, then if not catching something in the roller like a scatter rug, etc then the belt isn't tracking true. The pulley may have come loose for one thing, something has to be off to have the belt come off. Does it come off almost right away, or after some uasge?
Posted on Oct 03, 2008
The belt started to slip off the main drive belt to my U6420-900 this morning, and after reinstalling it a couple of times, it came off again. I tried a new one, but after approximately 7 minutes of operation, it also slipped off. After I read your similar problem with no solution, I started to check the alignment of the wheels, the roller, etc. then I noticed that the belts after a certain amount of use, they stretch, and become loose, I compared it to a new one and found a difference in size.
My solution was very simple. I took the old belt and cut off a piece of approximately ¼ inch, and then I reattached the ends by using industrial glue (Ethyl Cyanoacrylate). After approximately half an hour I finished vacuuming my entire house the vacuum cleaner is still working.
Posted on Apr 10, 2009
Belt keeps slipping off motor shaft
The belt may be stretched or worn unevenly.
Jun 18, 2016 | Eureka Smart 4870DT Bagged Upright Vacuum
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Apr 28, 2014 | Dirt Devil Vacuums
Belt keeps coming off
Hi There,
Most likely 1 of 3 problems.
1. The belt is stretched and so is just slipping off
Solution change the belt
2. THe brush roller has siezed bearings so brush cant turn properly so belt is slipping off the shaft.
Solution - check see if roller turns easily by hand if not change the bearings.
3. THe motor has twisted in its body due to cracked housing or worn rubber seats.
Solution- Depending on your skill and age of vacuum replace the housing or the vacuum.
If you need parts for your vacuum visit www.vacuumspot.com.au
May 13, 2012 | Oreck XL Ultra Bagged Upright Vacuum
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt installation
You will have to slip the belt over the motor shaft and strech it down to the brush roll that should be loosened from the bearing rest, slip it over the brush and strech brush back into position.
Sep 13, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka model 4870 belt replacement
- NO WAY AROUND THE END OF THE DRIVE SHAFT TO REMOVE DAMAGED BELT.
  • Following the belt replacement instructions in the manual, I removed the three screws, took off the base plate and removed the brush roll, slipping it out of the belt.
  • Up and somewhat inside the plastic housing I could see the other end of belt going around the drive shaft.
  • But the shaft had no gap around its end to allow removal or replacement of belts. It extended from the motor completely across the space and against the plastic housing.
  • Yikes.
  • I dismantled the housing until the end of the shaft was accessible and found that the problem wasn't the shaft moving out of position.
  • The problem was that the bushing mounted on the end of the shaft for the belt to ride on had slipped over.
  • Ah HAH.
  • I applied some LokTite green threadlocking adhesive (though neither the shaft nor the bushing are threaded) to the shaft, slipped the bushing all the way onto it and put it all aside to set up.
  • Finally I reassembled the machine with a new belt in place, plugged it in, crossed my fingers and hit the power switch.
  • It worked like new! FIXT! And I had only one screw left over. It was a small one too, so I doubt if it was important...heh.
Does your machine have a slipped bushing? You may be able to fix it without taking it apart any more than for a normal belt replacement. Try using a rubber or plastic-tipped forceps or pliers move the bushing back into position. Be careful not to mar the metal as it will chew any new belt to bits in seconds. If you are able to move it, put on a few drops of LokTite, epoxy or some other adhesive to keep it in place. You may be able to avoid sending your vac to the shop for costly repairs.
Apr 29, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuum smell
Your belt is slipping, it is probably stretched and slips trying to drive the brush roll. Take the bottom plate off, check the brush also, make sure the ends turn freely. The belt runs from the brush roll to the motor shaft. If you can't get to the motor shaft, then you will have to remove the top cover.
Mar 25, 2008 | Vacuums
I cant get the roller back in place
This guide should help.....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Please rate it when you are done reading it if it was helpful. :0)
Marci
Oct 02, 2007 | Oreck XLS700A Upright Vacuum
Hoover U6434-900 Bagged Upright Vacuum Logo
663 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
