I have 2 problems; 1st. after a recent paper jam, when ever i tried to reconnect the finisher i get the "finisher not connected" message. tried several times, pushing adjusting, angling to connect it, it does connect but the message won't go away. finnaly i disconnected it from the copier, but I have to use a box to catch the paper as it comes out of the copier. what else can i try? is there a manual on this finisher (booklet finisher w/hole punch and inserter)
2nd. after running about 8,000 copies, i get black toner spots all over the copies?
Comments:
Oct 16, 2008
- Chad, I'm not finding the black push button on the finisher or a connecting rod, I have a mj-6003n finisher with a post inserter attached. Are there any diagrams, photos, or manual available for finisher?
i have a problem how to solve the CB1 error code..at the service manual says "abnormal feeder motor",but i don't know which one is the feeder motor is..
There are a couple of different switches that could be out of alignment, or not "making" when you reconnect the finisher. If you will look on the copier, at the latch that connects the finisher to the machine, you will see a pointy shaft about 2 inches long. This rod comes in contact with a switch inside the finisher. There is a metal actuator on this switch that could need adjusting. Not a difficult job, but it will require you to take a few covers off. Also, there is a black push button on the finisher that is actuated when you push the finisher to the machine. If you are looking at the back of the finisher (the side that connects to the machine) it will be on the lower right hand side. It it operated by a connecting rod inside the finisher. This rod could have come loose. Again, not hard, but requires cover removal. Also, when you locate this particular push button, try manualy pushing the switch to see if this makes you message go away.
As for the black spots, this could be any number of things, but I suspect that that it might need a cleaning blade and brush, and maybe just a good cleaning in and around the drum unit.
Hope this helps,
C
Was this helpful?
Yes
No
Popular Solutions for Toshiba COPIERS - E-STUDIO 650
i press start butten. scan begining & finish. but machin not starting & writing on...
(More)
i press start butten. scan begining & finish. but machin not starting & writing on monitor copying my toshiba 550.plz help mi
We have a toshiba e-studio 550-810 printer driver gl-1020. It will only print the "odd...
(More)
We have a toshiba e-studio 550-810 printer driver gl-1020. It will only print the "odd pages" We've looed, and no we aren't printing to odd pages. It happens to everyone's machines. We reloaded the print drivers. We even had a new controller and hard drive installed. It still doesn't work. "The guy" is suppose to install a new board tomorrow, which leaves us with only a loaner copier.
