Question about Kitchen Ranges
GE XL44 Working fine but awful burnt propane smell
Hi
It's old about 14 years have replaced the igniters many times but this is mostly with the burners.As soon as you turn them on you get a very strong burnt propane smell-not raw propane like a leak would.Propane tank isn't low and the flames are solid blue not yellow or orange.Could it be the orfaces (sp) are worn and need to be replaced? They light as soon as you turn them on. Everything would appear to be aok with the cooking etc if it wasn't for this.Just started doing it-did not come on gradually
Thanks
    Top Expert:
  • Kitchen Ranges Master
  • 76,848 Answers
Remove the burners and clean them with EASY OFF oven cleaner. The passages are likely plugged and this causes incomplete burning of the gas. If you do smell raw gas shut the gas to the stove off RIGHT AWAY and call the local gas supplier.
Posted on May 12, 2017
SOURCE: GE XL44 range
that means that the flame is lighting at the orifice. that's where the burner sits on, pull out the broiler drawer, and stand back, turnd on the oven and take a look at that part of the orifice. you can pull down the pilot a bit lower, it can not be touching the holes of the burner, not that close, and it needs to be lower then the burner, that will stop the problem.
Posted on Dec 14, 2008
aborcass
  • 2651 Answers
SOURCE: GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Posted on Jan 11, 2009
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Posted on Feb 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Posted on Feb 20, 2009
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
I have a GE TrueTemp XL44 oven. All four of the burners are not working. The electronic ignition clicks and the gas is on (because I can smell it) but no flame is created. Any ideas? The oven itself on the...
Hi, To complete the circuit for the electronic ignition the 3 screwheads under the aluminum burner need to be really clean. The same goes for the 3 posts on the bottom of the aluminum burner. They touch to apply grounding for the ignition spark. GL!
Dec 19, 2010 | Kitchen Ranges
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
Have a xl44 it smells lkie gas when first lighting oven is it a bad part?
heatman101
Feb 02, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't work
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Aug 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 range
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
GE gas stove XL44
I have the same exact problem with my XL44, any ideas? Time to buy a new stove? If I do, no more GE for me!
Sep 21, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Kitchen Ranges Logo
59 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
