Question about Samsung PPM42S3 42 in. Plasma Television
Samsung Plasma PPM42S3 Dead
The set has no picture or sound. Fans will run after power button is pushed, stop, then run again and stay running and power LED will extinguish. Any ideas?
Thanks,
Jeff
  • Anonymous Dec 14, 2008
    samsung ppm42s3 plasma tv......
    It works for about hour after that picture starts wobling,snowy & cant watch.Again after cooling works for a another 30-60 minutes.Can anyone help me out here.
    Thanks!
    Aruna
  • arunaik_6 Dec 14, 2008
    samsung plasma tv PPM42S3Q,It only works for an hour after that pictures starts to WOBBLING,SNOWY,SOMETIMES SCREEN GOES BLANK.Nothing wrong with the input signal as i tried with dvd when problem starts.After 30min cooling it works fine again another 30-60 MINUTES.
    This tv is only 26months old.Pls let me know what might be the issue.
    Thanks
    Genius:
  • 1,139 Answers
Hello karnevil925,
I would suspect a problem with the power supply board (the switching power supply) or the power connection to the ignition board. You will need a schematic and a multimeter to test the power levels on the board.
I would suggest that you take this TV to a qualified TV technician for repair, since there is a possible shock hazard involved.
I hope this helps,
Thank you,
Shuttle83
Posted on Sep 27, 2008
Cannot get sound to work
read the owner manual if you have it---if set has lockout feature unless it also locks remote you should be able to operate with remote.
A few sets have a lockout that affects both remote and keyboard buttons==if no owner manual Google for it by model number or visit the Samsung? site.
May 20, 2012 | Samsung PPM42S3 42 in. Plasma Television
Samsung PPM42S3 42 In. Plasma Television no sound
See if sound when DVD etc is played and also look to see in menu if speakers are ON OR OFF.
My samsung plasma tv has no picture only sound. I've been told that it has "run out of gas" ??
Plasma screens do not run out of gas, this is nonsense, there could be several reasons why you have no picture such as a fault in the sustain board. There is the possibility the screen could be at fault also but not for the reason stated previously. Go to a reputable repair centre & ask them to estimate the cost of repairing the problem. If it is the screen then it would not be worth getting fixed, but as I said there could be another cause.
Dec 03, 2009 | Samsung PPM42S3 42 in. Plasma Television
42"lcd samsung tv,one year old has stopped working on digital and analogue but can work with a sky box or freeview box,ie it will not work on its own,thanks 42" lcd samsung wont work without a sky or...
sounds like it needs a re set
you need to press the following: (do not hesitate between presses)
s/by
info
menu
mute
s/by
when the tv comes back on follow original installation set up
Sep 04, 2009 | Samsung PPM42S3 42 in. Plasma Television
I was using the ppm42s3 for my xbox 360 and all of a sudden it went completely blank and now the tv wont turn on
You Probably have a bad Power Supply. But the X-Main bd,Y-Main bd could also be the cause of the malfunction. I have seen many times that all three bds can be bad. You need to have a trained Samsung tech troubleshoot the set.
Jul 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Plasma TV screen dull
yep, do u have a digital multimeter? if so, measure all the voltages from the power board located top middle. if u look at the top right of the panel, there is a sticker with va, ve, vset, vsc settings. ground the black lead, and use the red lead to read each of the settings on the pow bd. if there are more than 2 mismatches, its your power board and needs replaced.
Jan 03, 2009 | Samsung PPM42S3 42 in. Plasma Television
Samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 15, 2008 | Samsung PPM42S3 42 in. Plasma Television
Samsung plasma hd ps42097
Sounds like your power transformer is going bad inside the unit. Time for a repair man to visit you. Be warned, it's not going to be cheap. If you have a battery backup on your computer, try plugging the TV into that and see if it continues to shut down. If so, it's definately time for a repair man.
Steven
Sep 06, 2008 | Samsung PPM42S3 42 in. Plasma Television
Samsung PPM42S3 42 in. Plasma Television Logo
226 people viewed this question
Henry  Thomas
Henry Thomas
