The cycle buttons will light when selected but only the heated dry option will light.
SOURCE: AMANA ADB1500AWQ Control buttons not
unplug the power cable from wall socket.check the voltage from the household receptacle to the dishwasher, volt meter.It might be your neutral line is bad,or the console is bad
SOURCE: Dishwasher won't start
Try first unplugging power cord for ten minutes, and also holding the start button pressed for ten seconds.
If it still does not start, then see the suggestion below from Repairclinic:
It doesn't work at all
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Is
there power getting to the dishwasher? This can be difficult to test,
because dishwashers are usually wired directly to an electrical
circuit, rather than plugged into the wall. But at least check for a
blown fuse or a tripped circuit breaker.
Door switch
The
door switch is important because, if it's defective, the dishwasher
won't work at all. To reach it, you need to remove the control panel
cover, or sometimes the interior liner of the door. If it's defective,
you need to completely replace it.
Wiring
Often
the main wiring connection from the house, at the dishwasher, burns and
breaks the connection. If that's the problem, the wires must be
repaired/replaced as necessary. If that's not the problem, check the
wiring to the door switch, the wiring between the door and the lower
part of the dishwasher, and the wiring to the timer. Repair any broken,
burned, brittle, or defective wiring, using the proper appliance-grade
wire and connectors.
Although
it's uncommon, the timer or the selector switch may be defective. If
so, you need to replace the defective part, because neither of these
can be repaired.
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
SOURCE: Frididair GLD2250RDC0 The lights on
Sounds like the very common control panel issue. They have a tendency to short out due to overheating. It is possible it is the motor is bad, you can test power to motor with a voltmeter. If no power, then try power from control panel to motor. If there is power to motor, than motor is bad.
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
