Guide plus stopped working on my rca tv
What can I do to get the Guide Plus working on my 32" television
  • 1 more comment
  • stephenson82 Sep 28, 2008
    My TV is a RCA model# F27442TX51
    I've had this operating foe several years and suddenly it doesn't work any more. I've gone over all the instruction I have but nothing helps. It just doesn't pick up the signal carrying the listing. Anything else I can do?
    Again, the system has been operating for many years, when suddenly it stop working. I've done everything the user's guide says including checking all connections and setting everything the guide said to do, but nothing seems to help.
  • 2,071 Answers
The condition of your TV called power supply overcurrent shutdown. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating .I would probably also check the flyback circuit and flyback transformer although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Regards,
VOTIT
Posted on Sep 29, 2008
    Master:
  • 479 Answers
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
OR pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements. OR set up the zip code again and then see.
OR That is a common problem on the RCA tv sets with the TV-Guide plus
module from a couple of years ago.
To fix it simply unplug the tv set for a couple of minutes and plug it
back in to reset the Tv-Guide plus module and main system control.
What is happening is the TV-Guide plus standard included a commercial
audio mute feature, but the tv stations were banned from using this by
the sponsors. So the same code got used for some other network to tv
station use.
Problem is they never send the audio back on command and the tv locks
up the audio.
Thomson/RCA is aware of the problem and cannot do anything about
fixing the tv set as it meets the Tv-Guide plus standards at the time
of manufacture.
If this does not fix it the tv has a real internal failure that needs
repaired by a trained and equipped technician. OR have you checked to see if any buttons on tv are stuck?-do they all click or do you feel a click when pressing buttons?-stuck buttons can cause funny problems with these tvs
Posted on Sep 28, 2008
    Sergeant:
  • 208 Answers
I am not particular of your model , so i am giving three ways, either of the one will succeed.
Option A:
  • Select the GUIDE Plus+™ Menu from the Main menu.
  • Select Setup.
  • Select Options.
  • Select On.
Option B:
  • Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
  • Select On.
Option C:
  • Press GUIDE on your remote control.
  • Select the Menu bar.
  • Press the right arrow button to select Setup.
  • Choose Review Options.
  • Select On.
Hope my info helps you,
Thanx for using fixya,
Goodluck.
    President:
  • 2,712 Answers
Please check THIS link..
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Sep 28, 2008
    According to the list of compatible TV's on their website, RCA is not listed. Look here:
    http://www.europe.guideplus.com/En/our_s...
  • Swilin Sampson
    The guide plus comes in on the VBI
    part of the channel freq. This is the same part that closed captioning
    comes in on, is that working? Your cable provider can block this by
    limiting the bandwidth, but they are not supposed to be allowed to. Is
    the guide plus working on sat? You can also try bunny ears on one of
    the tv's and it should also work. Remember the plus info comes in when
    your set is off and it must not have anything blocking the "ant" in
    such as a cable box (have to leave it on) or a VCR (have to leave it
    off) for it to come in.
  • Swilin Sampson
    The verticle blanking interface
    (VBI) carries the cc and guide plus. The cc will be on that actual
    channel freq. if that network is transmitting it. The guide only comes
    in on certain local channels for the entire guide. When the set is off,
    it scans for that info starting at channel 2 and works up untill it
    finds the info. There have been some cable companies that blocked that
    info because they were trying to get extra revenue from their digital
    boxes doing it. From what I heard, they were not allowed to do this
    anymore.
    My next suggestion would be to default the tv by entering 99999 or 00000 for a zip code.
    You could try a self check on the tv. Most RCA's follow this pattern:
    1. Press Menu
    2. Select option 7
    3. Then Select option 1
    4. With "Set-Up" highlighted press menu
    5. Then press "Go-Back"
    6. Then press "TV"If "BUS" fails, then your television needs to have module replaced.
    If "VBI" fails, the signal needs to be reset with the "99999" reset.
    Hope that helps!!
  • 1,800 Answers
Just make all the connections then pres the guideplus button on the remote control.
plz do rate this post
  • 1,879 Answers
  • 6,487 Answers
Can you please inform us the brand and model of your unit so we can help you better...
  • Mark Gil
    Mark Gil Sep 28, 2008
    IF you have the user manual for this unit try to look for the steps to reset the unit and do that and hopefully that will correct the problem........
2 Suggested Answers
  • 245 Answers
SOURCE: RCA TV f27422 TURN OFF THE GUIDE PLUS
Remove your zip code, I had the same problem, when I removed the zip code it went away.
Posted on Jun 24, 2009
How do you disable the guide plus on a RCA tv?
Go to menu & choose settings. Change the zip code to all zeros. Then choose NO for all questions such as cable, VCR, DVD. This will disable guide plus from coming on when power is turned on.
Feb 24, 2013 | LG 32LX1D 32 in. LCD Television
My Guide Plus stopped working 2 months ago. Time
Also on Time Warner Cable and two TVs have stopped receiving Guide Plus in the last month.
Does anyone have suggestions?
Jun 09, 2010 | RCA F36650 36" TV
I want to open up the back of my rca tv and remove the guide plus
What?? Guide plus is a programming piece, not removable!
Dec 30, 2009 | RCA F32650 32" TV
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Our TV is stuck on a guide plus screen
i actually dont know what that is...mindboggling, right? call your tv company.
Jun 29, 2009 | RCA R52WH73 Projection Television
I can not get my tv to work with dish network
The RCA guide will not work with the dish remote. You can get the guide to close if you press the White TV button then press cancel. Remember to press the SAT button after you close the guide.
Nov 19, 2008 | RCA 32F531T 32" TV
Feb 09, 2008 | RCA F32650 32" TV
Rca guide plus gold 32'
Jan 16, 2008 | RCA 32F531T 32" TV
Guide plus rca tv how do stop it from coming up when turning on tv
I have a rca tv guide plus that has the back pannel lights on, but is unplugged, what is the problem?
Jan 04, 2008 | Televison & Video
Guide Plus
Not that I could find in the owners manual. Push guide or clear to exit.
Oct 04, 2007 | RCA F32669 32" TV
Televison & Video Logo
674 people viewed this question
Top Televison & Video Experts
