Question about Toshiba Satellite A135-S4527 Notebook
Laptop Screen Cuts off, but Computer Stays On
I bought a brand new Toshiba laptop on Ebay. Everyday, at least once, the computer screen will go black. I can still hear the motor running, and the power light is on, but the screen is off. I usually just turn it off and back on, but I was wondering what was wrong.
  • Toshiba Master
  • 787 Answers
Good chance the is a power saver option if it happens while you are not actually using the computer..
The computer will turn off the monitor after a certain period of inactivity to save power.
Go to the Control Panel, select Power Options and adjust it to what you want.
Posted on Sep 28, 2008
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
My brand new Toshiba SAtellite C850 F31Q screen stays black on startup. What can I do?
Got this from another site, since I had the same problem:
The problem is with the power settings, not the OS or anything else
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer. There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer. "
Aug 18, 2012 | Toshiba Computers & Internet
Brand New Toshiba Laptop Screen won't come on
That state might called comatose, during the shut down the battery gone low, so the system is in a hang state, after recharging to its full, then you power it on and the system try to recall the last status,sometimes needs reset and the system will work, other trick is remove the battery and PSU then push power switch several times to drain residual power and attach the battery and turn power on.If this will not work, the bios might be need reset, in this case you must claim your warranty service.
Sep 02, 2009 | Toshiba Satellite A135 Notebook
Hp dv6000 black screen problem
tipical hp problem, if no warranty buy a new laptop "not hp", its called "the good old fashion hp graphic chip burned"
Jul 02, 2009 | HP Pavilion dv6000z Notebook
Black screen
Might be a bad FL Inverter. Can you see any picture at all if you shine a flashlight on the screen?
Dec 07, 2008 | Toshiba Satellite A105 Notebook
Laptop freezes restarts or goes to a blank screen
its not the issue with the system
u have a usb printer connected to the system
disconnect that and start the system it should work
Nov 01, 2008 | Computers & Internet
Black screen
If it is brand new try return it first.
It sound like a computer virus some do that, try using an Anti-virus or an Anti-trogan. A trogan-virus is a malicious program.
Oct 29, 2008 | Toshiba Computers & Internet
Laptop motherboard
could be bad screen ok or video controller will have to have parts to test
Sep 05, 2008 | Toshiba (P000204210) Motherboard
Laptop monitor blacks out, but when you hit the toggle....
Sounds like you need a new Switch. Oxidation has probably built up in the switch. It can be fixed. Probably shop around for a certified tech who can replace it. The switch is cheap, Labor is starting around $65 - $90. You said you can faintly see the desktop. This is the invertor board inside the LCD assembly that causes this. Again if it needs to be replaced, the invertor is fairly inexpensive, labor isn't. The technician that ckecks out the laptop can determine what it needs. Yea, your right, it is a good laptop and it is worth fixing. Just a heads up, if the tech says you need a new motherboard, he's lying, find another tech.
Jul 03, 2007 | Toshiba 15.0" TFT Laptop LCD Screen
Toshiba Satellite A135-S4527 Notebook Logo
220 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
