Question about Hitachi 60FX20B 60" Rear Projection Television
Picture goes off and after the tv is jolted, the picture comes back on.
The picturee goes off, the sound remains. I hit the tv and the picture comes on. Does it need a new lamp. If so, where can I find one.
  • stclairja Sep 27, 2008
    Thank you very much. I will try this.
  • 958 Answers
Nope. it just have a loose connection or what they call cold solder issue. if you can find it and resolder it then you can fix it.
tnx 4 using fixya,
drcool
Posted on Sep 27, 2008
    Genius:
  • 1,550 Answers
Do you often get this problem or do you get it occasionally ?
If you get this problem often then change the lamp
This will be available in
http://bumblebeestoves.com/484.html
SAM ANDERSON
Vw42L tv comes on withpicture for 5-10 seconds and screen goes black ,sound is still on
Most likely you either have a defective backlight inverter, bad back lamp. Based off of your model #, I'm gonna lean towards a back lamp.
May 10, 2012 | Vizio Televison & Video
Picture goes out but sound remains. After restarting picture is back. Recently the picture would not come back after restart. Next day it worked again.
The tv have 1 or 2 long LCD inverter boards are dying.These 1 or 2 long LCD inverter boards help the tv to have a backlight to produce a picture on to the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 LCD long inverter boards for the replacement.
Mar 23, 2011 | Dynex DX-LCD32-09 LCD TV
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Apr 27, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Picture goes away not sound ,hit the back of tv
You need to take the back off the set, with the power off, turn it on, then probe around with a long, wooden chopstick until you find the problem.
Apr 05, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
I have a 2008 toshiba regza 46 lcd. somebody jolted it back and forth while on stand..and the picture started to go dark immediately. Is it damaged?
If the panel was hit when jolted it may have shorted out the panel. It may have just jarred a connector loose to the panel or some other board. You can try unplugging it for about 5 minutes and see if the picture comes back. If it doesn't come back on, connections should be checked and reseated. If that doesn't work or there is a crack in the panel it will be cheaper to replace the set. Have it checked at a repair shop to make sure a board didn't crack.
Sep 01, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Hitachi 60FX20B 60" Rear Projection Television Logo
99 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
