Wont spin small loads - Washing Machines
  • garymerrill Apr 11, 2009
    on spin/drain cycle washer stops, espically with SMALL load
  • john gagnon
    john gagnon May 11, 2010
    hi thanks for the question does it spin on large loads
  • 943 Answers
Hi thanks for the question i think the problem is with the motor coupling located at the motor & clutch . move washer away from the wall and look underneath .if its ground up pieces . replace the coupling thanks the appliance doc
Posted on Sep 28, 2008
Wont spin
Good Morning Anthony,
I see that you are having trouble with your Frigidaire washer, model# FWFB9100ES0 not spinning. There are a couple things I would do. First check the dispenser drawer and make sure it is closed. This can hinder the appliance from spinning the clothes out. Another thing to check would be that the load isn't too small. If it's a small load it can become unbalanced. Add 1 or 2 similar items to help balance the load. If these suggestions do not work, you can always try resetting the washer by either unplugging it or cutting the power at the circuit breaker for at least 2-3 minutes. When you restore power try the cycle again. If you are still having trouble, I suggest contacting either the manufacturer or your local authorized technician. I hope this has helped.
-Best Regards-
WP
Mar 25, 2014 | Frigidaire Washing Machines
My washing machine wont spin with clothes in it
Hi, you will find either the drive belt has stretched slightly so when the unit is under a load the motor pulley slips on the belt. The belt should have some sort of tensioning or you would need it replaced.
The other reason it will not spin is if the motor brushes are worn and need replacing.
Hope this helps.
Mar 22, 2010 | Washing Machines
Wont finish a small load. Gets to 4 minutes and
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Nov 17, 2009 | LG WM0642H Front Load
Washer wont spin
warning disconect machine before you work in it check under machine there is small white plastic is located in the motor is broken becarefull dont touch any electical parts or your machine belt might be broken too i recomen u use gloves good luck
Nov 05, 2009 | GE WSXH208A Front Load Washer
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
My washer says E20 and wont spin. Any suggestions on what to do to try to fix it?
I think I had same problem.. It was because my load was very unbalanced.. I had a hevy item with a few small items inside..
These front load washers have sensors for the weight balance.. If it is to heavy in one spot - it wont spin...
Jul 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
GE washer model #wle4000b1ww won't spin
This is joyce
You have a bad belt it wont pull the load.
thanks,
joyce
Feb 04, 2009 | GE WPRB9220D Top Load Washer
Washer will not spin
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Won't spin
Jessi, you need to call for factory service so you wont void the warranty. A couple of things could be going on here. The filter before the drain pump could be clogged with stuff preventing a high spin. Pressure switch wont allow a high spin if it detects water in the tub. The main control and motor control talk to each other and controls the spin. There could be a loose harness or poor connection at one of the boards. I would call for service, it won't cost you a cent...Catriver..post back.
Mar 15, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
