Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Ink Cartridge Problem
This is a new installation -- the black and blue cartridges are working fine. Problem with the yellow and magenta, error message reads -- install yellow
  • 4 Answers
TRY THIS FIRST!!!! it is the easiest and works everytime for me. Just unplugg it. I read somewhere, probably here, to do this. Actually pull the power plug out, not just turn off. I also took out the connnection plug to the computer for extra measues. Wait a few minutes then plug everything back in and turn on. It is like a computer rebooting. The printer will reinitalize itself and do a systems check. All the cartridges were recognized and the inkloads were correct. Had the same problem when I change the Black. Unplugged everything, and then perfect. I really like this multi function printer. it is the best for the money, cartridges are individual and cheaper then others. So if I need to just unplug every now and then not a big deal.
oh, I have always only used Brother cartridges, so I do not think it is cartridge problem. Before doing the tape just try this first. Wish I would have known about this solution with my previous one which obviously I threw away and did not have to.
Posted on Oct 03, 2008
I am still not able to resolve the error message below after trying suggested solutions. I might add that my printer is not used frequently. Could it be damaged beyond repair because of this? Getting...
Hi, do note that even if you are printing in black, the printer requires that you have installed functioning cyan (blueish), magenta (reddish) and yellow cartridges as well.
Feb 10, 2015 | HP PHOTOSMART PLUS B209A All-In-One...
Getting error message...the following cartridges red blue yellow appear to be missing or damaged. I removed the red and blue cartridge. There was no yellow,cartridge. The only cartridge I have in th
Hi. Most ink cartridges are cyan magenta yellow and black. You do have to have all cartridge installed for it to work. If it's been sitting for a while ink dries and can cause all kinds of little problems. The ink cartridges have little contacts on them you might have to clean these with a cotton swab and alcohol. But if the ink has dried in the print head you have to clean all the little ink ports on the head.
Feb 10, 2015 | HP Office Equipment & Supplies
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Epson c90
did you remove protective strip from cartridge
Jul 24, 2008 | Computers & Internet
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
Aug 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
100 people viewed this question
James Cagle
James Cagle
Jim Keysor
