Question about Boating
Clarion Marine M5170
The above mentioned unit has a pigtail with a red and white RCA jack coming out of it and a fixed red and white one flush with the back of the unit. In both cases, they are female recepticles. Can you tell me if these are for an auxillary input? A subwoofer ouput maybe? I don't want to try anything and risk "frying" the unit. It is the original sound system in my 1997 Sea Ray if that helps in looking anything up
  • jschiller Mar 07, 2009
SOURCE: Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Posted on Mar 05, 2008
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
SOURCE: Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
  • 21 Answers
Most covers hold themselves in place. You may have to pry it a little harder. It could have rust around the edges and will not come out easy.
Posted on Dec 01, 2008
  • 4 Answers
SOURCE: Bose Acoustimass 15 woofer, Replacement of RCA female connector
On the end opposite of the jacks (top of the sub opposite connectors) in the exact middle, there is a ratchet looking device (flashlight and magnifying glass reveal the little culprit) with a very small flat screw driver rotate the piece CCW until a small tab is protruding from the middle. Pu the palm of your hand on the plastic case and give it a small whack (in the direction of the jacks) it will move about a 1.2 inch. Lift straight up and the case will come off and reveal the connectors. Trust me, get a flashlight and magnifying glass and peer through the small crack between the cover and the box, you will see the little notch (encoder looking) rotating wheel
Posted on Dec 15, 2008
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
I need to know what rca output jacks are what grey purple black and red
1 FRONT RIGHT Gray (Red) 2 FRONT LEFT Gray (White) 3 REAR RIGHT Black (Red) 4 REAR LEFT Black (White) 5 SUB WOOFER/NON FADER RIGHT Violet (Red) 6 SUB WOOFER/NON FADER LEFT Violet (White) 7 AUX INPUT RIGHT Red (Red) 8 AUX INPUT LEFT Red (White)
Any Problems the manual is to found on this link, Regards
Mar 29, 2011 | Clarion DXZ655MP CD Player
Wiring Freedom 20 inverter
make sure your new inverter is made for 220 volt supply as that is what the red wire represents. its the other leg of a 220 circuit and should not be connected to your new inverter until you read the manual to see if it is designed for this and if so how to wire it in. it could cause you are the unit serious harm if you connect a 110 inverter to a 220 circuit. consult an rv repair shop or a good electrition if you cant find the needed info. it may actually be printed on the side of the inverter as well.
May 27, 2010 | Xantrex Technology Heart Freedom 30...
Where do the RCA jacks plug into on my clarion VRX755VD DVD playe
in the back of the unit where all the other wires are. they might be dangling out with the rest of the wires or they might be flush with the unit
Dec 21, 2009 | Clarion VRX755VD Car DVD Player
I need to know the wiring diagram for a Clarion
Sep 20, 2009 | Clarion XMD2 CD Player
Just got a clarion xmd1 but the wires are cut off at the plug
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Jul 30, 2009 | Clarion XMD1-RET CD Player
Can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Jun 05, 2009 | Clarion M255 AM/FM Marine CD Player
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Clarion xmd3
Yes, there are 2 Red RCA jacks on the back. A $10 cable from radion shack, 2 RCA on one end and a 3mm jack on the other.
Cheap way to do it, there is also a device you can buy from Clarion that will do it for about $90 that gives you more control from the radio.
Jun 23, 2008 | Clarion XMD3
Boating Logo
316 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
