Rca tv hi eagle we spoke with you last nite regarding our rca tv. looking at schematics and nothing shows as flyback it shows as line filter.......part L14201 is this the same thing
  • donnamw1963 Sep 27, 2008
    the part number we kept coming across was 239111 which we assumed was the flyback.....do you know what part this would be.........is the vertical output ic the same as the vertical out amp ?
    thanx
  • 4,889 Answers
Yes that is the correct part number.. If its not the flyback then i would bet on the dry solder at the vertical output IC.. Check it and let me know..
Posted on Sep 27, 2008
Flyback no. 25gt539
Try Suburban Electronics as they sell generic replacements for these older RCA and GE sets---If you need the part number look for a Howard W. Sams Photofact for this set, has schematics and a complete parts list included.
Dec 13, 2012 | GE 25GT539 25" TV
RCA D52W20 Light blinks 3 times, Replaced Flyback, Caps
I have the schematic, did the same thing and still have the problem. Any help?
Aug 12, 2009 | Televison & Video
I had color shadows and then the t.v went out for good.
Check your color guns first. Sometimes they go out of alinement from jarring of the TV. Also if your getting lines on the top or bottom of the screen. That is your data lines for video and or color. Check the pods in side if they can be adjusted. It not then your have to have a shop set them with a meter.
Jun 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on; remote/tv power switch inoperative
hi I am Vortash .. burning smells usually mean Power supply or line output .. flyback problems .. this is probably one of those jobs only an engineer should look at .. voltages on the line can exceed 400 volts and are highly dangerous the line output from the transformer depending on the type of tube can be up to 25,000 volts .. so best leave this one to the proffesionals Regards Vortash
Apr 25, 2009 | iLO IWT3206 TV
Tv shut down and I found the HOT to be shorted.
this set is famous for defective flybacks. part number is 262342. replace the flyback
Jan 09, 2009 | RCA 36V430T 36" TV
No power
The P56940 uses the PTK195 series chassis. The most common reason for that chassis not running is a shorted flyback (high voltage) tansformer. Sometimes a shorted flyback transformer will also cause the horizontal output transistor to short, and then the power supply will "chirp" when plugged in. The set should be serviced by a qualified tech familiar with the 195 series chassis.
Aug 27, 2007 | RCA P56940 56" Rear Projection Television
Replaced Flyback Transformer and now the colors are screwy
It is possible that the degaussing thermistor fell out while you wer changing the IHVT. RCA is famous for the bi-metalic thermistor falling out or just one wire becoming disconnected. look next to the fuse and see if there is two wires sticking up with nothing connnected to them. If this is so, look inside the tv for the thermistor. You can actually repair it by burnishng both sides with a small file and then adding solder carefully while out of the tv, then brazing both leads to the thermistor. Also make sure if the chasis is a ctc203 that the inductor connecting the base is resoldered. This is the main cause of the shorted H. out and the shorting of the Ihvt. Always re-solder all suspect connections. 80% of all newer tv's problems are the result of poor solder connections. Since the formula was changed %lead to tin many companies have had numerous problems with wave soldering.Scrivitron
May 31, 2007 | RCA F32649 32" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Horizontal Line
Your problem is called a vertical sweep problem and is caused by a defective vertical output IC,a bad vertical output coupler capacitor, and/or the b+ from the flyback transformer feed resistor and the filter capacitor. You get a schematic and post it here and I'll show you what parts are the most common in this chassis. You can get a service manual from Sams photo Facts on line and downloadable. Good luck
Apr 23, 2006 | Panasonic CT-27G22 TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
