i have changed the mother board and when i connect the plug the computer automatically turns on but the monitor stays blank.I have checked the monitor with another computer and the monitor works fine. All the cbles are connected correctly
-   I have a Dell Dimension 8100 that won't turn on. Power is on, Monitor is good, splash screen won't come up, The computer will not start-   T_Byrd653
Oct 20, 2008
-   I CAN NOT POWER UP MY LABTOP
-   BLACKISKNOWL
Check on *********** board that your CMOS jumper is in normal mode otherwise change it - also check any beep sound aswell as you remove all the cables ie.. IDE cables, front panel cables I mean only the 2 power cables to the motherboard and try to start the pc by shorting the power switch pin with a screwdriver see the display coming or not ????
IF it is a branded pc - you have to buy the same companies motherboard, normal motherboard will not work with branded pcs.
jumper was blown off during maintence,i put it back to where i thought it was only to discover i...
(More)
jumper was blown off during maintence,i put it back to where i thought it was only to discover i NOW need a password.
i have a dell dimension 8100 and the video wont power up. i replaced the adapter and it is still...
(More)
i have a dell dimension 8100 and the video wont power up. i replaced the adapter and it is still doing the same thing.
