Question about Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower
Oil stick is stuck
I can't check the oil of my Craftsman 2550 psi pressure washer.
I don't know how to remove the oil stick. It only turns 1/4 left or right.
Please, Help.
  • mtorres0707 Oct 08, 2008
    There is no screw on the cap. I verified a new one at Sears. The problem was that the last one who pulled it out, replaced back the cap in the wrong position.
    Thank you for your help.
    Scholar:
  • 62 Answers
Have you ever checked it before? Do you know if it's a screw on cap? It could be that the cap is slotted, and is only supposed to turn a 1/4 turn. Try not to force it, and use a light touch.
Hope this helps!
C
Posted on Oct 08, 2008
Water in oil
sounds like the head gasket is gone once water mixes with the oil
Aug 30, 2012 | Briggs & Stratton Garden
I have a Troy Bilt 2550 psi Power Washer with a Briggs and Stratton 675 Series, 190cc engine. Could you tell me what kind of oil I should use.
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Jul 02, 2011 | Garden
I bought a new craftsman pressure washer 2700psi. Put oil and gas in it. Cranked on the first try. It worked for about 15 minutes and then cut off. Now the pull start is very hard to pull and will not...
Hello
Take out the spark plug and try pulling,if it is still hard then then there is a problem with the pull start mechanism.
Check the plug for oil fouling or fresh oil.If there is excessive oil you may have bad rings.
If in doubt, craftsman will honor the 1 year warranty no questions asked,for a new unit.
Jun 25, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Pump burned up?
The unit does not have auto shut off? Anyhow try to take out the oil and flush it by running good oil in and let it out again…then put oil and first see if you can turn it manually few turns and see if you hear any sound…then try to start it and see…let me know
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | Honda Pressure Washer PSI 3000
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Jun 23, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
JUST DON"T KNOW
I have one also all it required is 2stroke engine oil
May 11, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower Logo
315 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
