Question about Toshiba TDP-MT800 Multimedia Projector
Toshiba TDP-MT8 Power LED green/yellow but no lamp even after replacing
I have a TDP-MT8 Digital Projector. The Power LED is lights green/yellowish but no lamp even after replacing the lamp unit. Also, neither the power button or the remote power button turns the unit off - no response.
  • 1 more comment
  • elad488 Oct 23, 2008
    I have the same problem with the Toshiba TDP-MT8U from looking around on this website it seems this may be a power supply or ballast board issue?
    A little bit more info: When plugging in the projector after replacing the bulb it just sits there for a little bit then the LED will blink a greenish yellow. The unit is nonresponsive and the fans sometimes turn on and sometimes don't. I had this problem once before but got lucky and once when I plugged in the unit the LED was green and it was back to normal for about 3 weeks. Now it is doing the same thing and I have not been able to get it to turn on again.
  • geralddea Nov 08, 2008
    I have the same problem with mu Toshiba TDP-MT8U
JayBlair
  • 328 Answers
SOURCE: Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
Posted on Aug 08, 2007
  • 9 Answers
SOURCE: Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Posted on Jan 22, 2008
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
SOURCE: Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Posted on Dec 28, 2008
  • 22 Answers
SOURCE: Projector power problem
I HAVE THE EASY FIX!
I had this same problem & almost threw it away!
If you have had it unplugged for a while just plug it in & make sure the yellow power light is on, then leave it plugged in for about an hour or two. Do not try to turn on before at least an hour, then it can easily be turned on. Make sure you reset the lamp timer option. There & you thought it would be difficult & expensive!
Posted on Jan 09, 2009
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
TDP-MT8 Digital projector will not power up
Found parts availability not available for this model.
Nov 25, 2009 | Toshiba TDP-MT8 DLP High Definition Home...
My MT8 will not turn on. I press power and the
Seems like you have a power supply problem. I can repair the projector. If interested i'm on ebay my screen name is gtitubro.
Oct 02, 2009 | Toshiba TDP MT8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba MT8/Infocus 7200 broken power board
I can repair the power supply for you for 150 flat fee. Look me up on ebay i have a 100% feedback selling projectors. My ebay id is gtitubro.
Apr 11, 2008 | Toshiba TDP-MT8 DLP High Definition Home...
Toshiba tdp-mt800
Hi there
Have you tried using another input like the Component instead of the DVI. See if it makes any difference.
If not it could be the DMD or your Mainboard.
Most of the time it is the Mainboard - Home Theatre Projectors come out with awesome DMD's , so I doubt it to be the problem.
Hope this is usefull !
Aug 08, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
Aug 07, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
Toshiba TDP-MT800 Multimedia Projector Logo
150 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
