The screen on my Wharfedale LCD2610H DAF is broken. the TV still works only the image can be seen properly. can this be repaired and how much?
Wharfedale tv
Sadly, it's probably not cost-effective to repair this TV. The prices of large screen TVs are constantly falling, so my advice is to replace it with a newer model and sell the Wharfedale as faulty on eBay.
May 19, 2014 | Televison & Video
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
Replacement screen wharfedale lcd
need the screen part number will be on the back of the screen.
Sep 29, 2013 | Televison & Video
I have a wharfedale 64cm tv and it went in for repairs .i do not have the manual for the urc-3415 remote and desperately need the code.please help
Wharfedale 0037, 0556
  1. Press the TV key on the ONE FOR ALL
  2. Press and hold down MAGIC until the red light blinks twice. (The red light will blink once and then twice.)
  3. Enter your (four-digit device code) using the number keys. The red light will blink twice.
  4. Now, aim the ONE FOR ALL at your device and press POWER. If your device switches off, the ONE FOR ALL is ready to operate your device.
  5. Turn your device back on and try all the remote's functions to ensure they are working properly. If the functions do not work properly, repeat steps 1-5 using another code listed under your brand.
  6. If your device does not respond, follow steps 1 to 5 with each code listed for your brand.
May 17, 2011 | One For All URC-3415 Remote Control
One half of the lcd tv loads fine, picture is perfect. The other half of the tv screen appears to struggle to warm up and appears much darker. In fact the image lingers when one program ends and another...
How old is your LCD TV?
From your description of the problem. It appears to be a moisture related. As the TV is ok after a while.
Power off your TV before carrying out next steps.
I would check the wiring connections first and see all connections are good. Also vacuum clean of dust using a brush is recommended.
Secondly would use a hair dryer to blow hot air into to TV unit via the exhaust vent. Just ensure that power is not switched on.
on your TV when you use the hair dryer.
i would also suspect a possible bad joint of a component on the mother board. A visual inspection is required to see the motherboard.
Also a component failure is a suspect due to aging..
You need to evaluate if it worth repairing the TV. Repair cost can be prohibitively high.
hope that helps. good luck.
Sep 10, 2017 | Wharfedale DVD-M3 DVD Player
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Oct 27, 2009 | Televison & Video
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
