Question about GE Profile WPRE6100G Top Load Washer
Does not turn off after a wash
Just bought one of these a week ago and it does not turn off when done washing. What i mean by this is I hear a low humm and I have to manually push in the button on the top to get it to stop. I called the 1 800 service number but it is automated to come out to the house for a service call. I really just want to speak with some one first to tell me if this is normal or not before I call them again as I already had them out to the house because when they hooked up my washer they mixed up the hot and cold water lines. so far I am not too happy with this wash machine.
  • mikeroxy_10 Sep 27, 2008
    Thank you for the info. I checked the water temp when I put the controller on cold/cold and within a few seconds hot water started to fill up the tub. How do I fix this? Is it easy or do I need to call service out AGAIN (they should have caught this the first time when they noticed my hot cold lines were swapped during install) or can I fix it easilly? Once this is fixed do you think this will solve the problem of my washer not turning off (humming) after a cycle? Thank you for your advice.
  • mikeroxy_10 Sep 28, 2008
    Thank you. there was a problem with the hoses. The leg of the washer was actually on the cold water hose crimping it so we could not get cold water. Now my washer is working, but still am not happy with the install crew or service, both should have noticed this.
    Thanks for your advice
  • 943 Answers
Hi thanks for the question the low hum you hear is this on the start of the rinse cycle if it is you could have a water valve problem change the water temp control and see if you get water check that but i do think you have a water problem if you select cold water do you get cold or warm .do you only get hot
Posted on Sep 27, 2008
  • john gagnon
    john gagnon Sep 27, 2008
    hi yes reverse the hoses at the taps this will solve the problem thanks the appliance doc positive feed back is nice thea appliance doc
  • john gagnon
    john gagnon Sep 28, 2008
    thanks glad its ok
Frigidaire dishwasher model FDB520RHS2 will not advance pst wash- just keeps washing draining and refilling the wash. does not advance. Left it run for 3 hours, still wash only
We had a problem with our dishwasher, it just went crazy one day and lights would light up but ours did not wash or anything...anyways upon further investigation found out by taking 6 large round head screws off,, the handle and outer cover came off, then there was a cover that was covering a circuit board and this was the brains of the washing machine, ordered the part from sears 160.00 and washer is all set. good luck. oh ya, upon further exam. when I took the board off could see discoloration on part of the circuit board. this means burned out resistor or fuse.
Mar 22, 2014 | Frigidaire Dishwashers
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Dyson CR02 F11F2F6V205S Error Hi, I have A Dyson CR02. The drums seized years ago and Dyson converted the firmware to act as a single drum machine. The first half of the front display stopped working...
Sorry to hear you're having difficulties with your Dyson Contrarotator. It's probably best if you get in touch with us directly, so one of our experts can provide the information and assistance you need. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 06, 2011 | Dyson Flowcheck CRO1 Front Load Washer
I have a wf-t1340tp washing machine I bought a week ago. it takes more than an hour to wash a load. is it normal?
Is it taking a long long time to fill with water or is it washing for that long or spinning for that long or just waiting between cycles for that long. The maximum time should be around 30 minutes or less.
Apr 15, 2010 | Washing Machines
From kim , we have a wm12311fd i put a wash in a
CHECK WATER PUMP FILTER IF OK CHANGE PUMP.... hope this works..01179512835
Dec 30, 2009 | LG Washing Machines
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
Hi, I brought a Bosch front loader washer 8 weeks ago. It's been working fine. This morning did 1 load of washing, then washed a jersey on wool setting. When i checked to see how the load was going the...
If you look int the back of the care and use there is a section that says, Trouble Shooting minor faults. E02 is a water fault, low water, pinched hose, water turned off, clogged screens in water hose or water valve. Hope this helps. The section tells you what to check. Jeff
Apr 22, 2008 | Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
53 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
